9e / XJ Integration
  • Thread starter Thread starter NDPILOT
  • Watchers Watchers 40
Here's the scenarios and the probable winners and losers:
1. Date of Hire
Winners - Senior XJ, Mid-level 9E
Losers - Senior 9E, Junior 9L
2. Relative Seniority
Winners - Senior 9E, Junior XJ, All 9L
Losers - Senior XJ, Mid/Low-level 9E
3. Ratio Blend
Winners - All 9E
Losers - All XJ, 9L
Oh yes they will! Just watch. Your airline got bought. Not the other way around. Prepare to get screwed.
Nice, can't wait until you're my FO.
When all is said and done, you'll probably be praying for a 2-1.
"Decides" to get greedy? They already are. All of them.
I'm not your FO yet. Lots of 9E guys are forgetting it's a union matter. If we don't get something that's fair, we walk or it goes to mediation. Is there a chance we here at XJ could get screwed really, really, bad? You bet. But I still have faith that even Phil and his management team don't want this to get ugly and drag on.......could be wrong though. The Mesaba MEC will be running the show going forward as 9E MEC has asked us to lead the way.
Have you even been paying attention with what is happening at 9E? Our union has been helpless with the NMB not moving one bit! If anything they have put us on ice, AGAIN! And YOU can't walk until the NMB releases you into self help, then you have a 30 day cooling period, and then you can strike. The only other "walk" is you quit your job or get furloughed when assets (read: CRJs only) from your airline are transferred to Pinnacle.
Faith and Phil should NEVER go in the same sentence. Your faith has been sorely misplaced. And you will regret it. 9E mgt is out to screw you. Wake up and smell the screwing! This will not drag on. Nothing stops Phil and the gang from doing an asset transfer and moving your airplanes, and then merging the props to Colgan. That union and ALPA merger policy (SLI rules) will only come into effect when it is a MERGER.
Listen, we can go back and forth all day long. The way I read the scope language as posted earlier allows Mesaba pilots to go with the airplanes in the event they are TRANSFERED (ie Asset Transfer of airplanes) to another company. It seems you are missing the find print in the language. Phil will come across some major road blocks if he tries to pull this off. Just sayn'.
Bull!!!! you can all walk whenever you darn well please. See the NYC bus strike a couple years ago. The only thing you need is a group (and especially the union leaders) with a giant set of brass ones to basically tell the NMB and the government to blow them! They can't and won't throw everyone in jail. Is it risky, sure. So is everything else about this job.
City bus systems don't fall under the RLA. The American pilots tried that with a sick out in the 90's over an acquisition/merger. The monetary damages awarded by the Federal Courts essentially broke the APA. Their next contract after that was concessionary in order to satisfy the damage award. If an ALPA property tries that they will be excommunicated by ALPA so fast they won't recognize the quicksand they will be standing in. PNCL management has in the past used the Federal Court system and appears to be willing to use it again.
They were under order not to strike and did it anyway. Not sure how that would be different. I did say it would be risky, everyone may well end up out of work for good. Also everyone should be putting pressure on their rep/senator to repeal the RLA.
MAIR used the Federal Court system too. Believe me, this is my 5th holdings company since I started here. XJ has been through alot, maybe more than 9E. We have been successfully released in the past. Our MEC is strong, resilient, and resourceful. They can actually be an asset to 9E negotiations and bring a signable TA to the table. Don't think we haven't dealt with a management team like this before. If we work together, we can succeed. If you (all negative posters) continue to propogate the negative, you will only cause a division in the pilot groups and we will DEFINATELY fail. Time to get on the same team here.
So you think this is going to turn out differently than the Colgan - PCL integration arbitration? Precedent is already set bud... just saying.
you're an errand boy sent by grocery clerks to collect a bill...
