250 below 10000
JungleJetCA said:
Okay, you guys. There were at least two posts in which someone wrote that there is a speed limitation in Class B. There is not. The speed rule is 250 knots below 10,000. This is everywhere. And it's this rule that was waived in IAH, not some fictional Class B speed restriction. If you are in Class B at 11,000 feet, there is no speed restriction. I've flown with guys who do not speed up at or above 10K in Class B because they are under the impression that Class B has a speed restriction. Maybe back in the TCA days but since they gone to calling it Class B, the 250 at 10 is not associated with Class B.
My bad. I meant C&D, not B&C.
XTW said:
If you are more than 12 miles offshore, let 'er rip baby!
Very true... there is an FAR that I read a while back that exempts the 250 blo 10k rule if you are over water. I know LAX has this waiver when taking off to the west. Once the aircraft has reached a certain point beyond the shoreline, socal dep will usually increase speed on the loop4 dep.
Workin'Stiff said:
You'd also be in international waters....
Or hopefully over 'em...
And I can agree with the CLE controllers. What are they doing up there?
Why do I constantly hear "Cross GONNE at ___ and 170 knots"
What is UP with that?
Oh...while we're bitching about CLE. What is up with this:
"Cleveland, N123 airport in sight when it helps"
"thank you, proceed direct downtown expect the visual 24R"
"direct downtown visual 24R N123"
*over downtown*
"N123 maintain 3,000 intercept the localizer cleared visual 24R"
"uh....3000 Visual 24R join final"
??? It's a v-i-s-u-a-l....I can see the airport....and the centerline...I don't need the localizer to tell me how to fly to the runway. Sheesh! Rant off!
-mini
Well, I learned something new I guess. Taking off from a Class B airport, there's no need to stay at or below 200 kias until 2,500' or 4 nm? Am I reading that correctly? That only applies to Class C and D airport surface areas? Doh! I feel dumb!
Read subpart (b). Subpart(d) also allows you to speed if the aircraft requires it. And I think subpart(b) also indirectly tells you the Administrator and ATC are not one and the same. It looks like ATC can ask you to speed only if you are at or below 2500' and within 4 nm of the primary airport in Class C or D but can't tell you to go faster then 250kt unless subpart (d) applys to you.
Sec. 91.117
Aircraft speed.
(a) Unless otherwise authorized by the Administrator, no person may operate an aircraft below 10,000 feet MSL at an indicated airspeed of more than 250 knots (288 m.p.h.).
(b) Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet above the surface within 4 nautical miles of the primary airport of a Class C or Class D airspace area at an indicated airspeed of more than 200 knots (230 mph). This paragraph (b) does not apply to any operations within a Class B airspace area. Such operations shall comply with paragraph (a) of this section.
(c) No person may operate an aircraft in the airspace underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 knots (230 mph).
(d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed.
an example - correct me if I'm wrong...
Aircraft departs a class B airport - standard departure - no restrictions. ATC issues a "level at 10,000 feet / maintain 10,000 feet" restriction.
1) you are still in class B airspace (at 10,000')
2) there is NO speed restriction for class B airspace
3) the 250 KIAS <10k restriction does NOT apply
p.s. I sure miss the departures out of Canada (310KIAS @ 3k) what a climb rate.
To keep yuo boxed...
-mini
Hey Mini,
When you are given a visual approach you can determine your own path to the runway and altitude subject to any other applicable limitations. By clearing you for the visual apch via the localizer and/or altitude limit, the controller is ensuring that you will not go monkeying around and buzz you girlfriend's house. Here in LA, we get cleared the visual rwy 25 (HHR) via the localizer. Why? They do not want us venturing further into Class B to our right. If you do, in that case, you could be violated without the excuse "hey... he cleared me for the visual!"
Swerpipe said:
Hey Mini,
aaaah......well I guess that makes more sense then
*opening mouth to take foot out*
Thanks!
-mini
Speaking of Canada...What exactly is the rule for speed below 10. Someone told me that you can do more than 250 when departing and below 10, but on arrival below 10, you are limited to 250 or less.
For practical purposes, this is all in Canadian airspace.
Yes, in the language of the regulation, if it states, "Unless otherwise authorized by ATC," (or similar language) then the Air Traffic Control can provide the relief. If it states, "Unless otherwise authorized by the Administrator," (or similar language) then the only way to obtain relief is to petition for an exemption through Part 11 (which is a four-month process).
You have to be careful there, aero. A friend of mine is a radar controller, and sometimes I used to visit with him(pre 9/11). We were sitting there looking at an arrival string, and everyone had a 250 kt restriction. Every aircraft was arriving at the intersection with a groundspeed of about 320, give or take a couple. Then this yahoo comes over and his groundspeed is 380. So my friend asked him his speed and the reply comes back: "250"
We chuckled about it for a couple of minutes, and then he says, if it had resulted in a loss of separation he would be so busted.
Did I read somewhere that the new Gulfstreams have transponders that display IAS on an ATC scope ?
Had a late night mini debate with an approach controller at PBI a couple of months ago over this very issue. He told us we could disregard the 250kt restriction and I basically told him I didn't realize he was authorized to clear us for that. He was basically saying to do it and he wouldn't tell me. Not on your life! The same guy told me I could keep the speed up (disregard the speed restriction) just a couple of days ago. We ignored him and made sure we were at 250 when we hit the offshore limit.
Now, what's with guys taking off out of FLL or PBI that think it helps one iota to go 340 kts the instant they are 12 miles offshore at 5000ft or so? Go fast on the descent when you aren't blowing fuel out of the tailpipe. In the climb, there is no value to going throttling up for a few minutes at higher speed and disproportional higher fuel burn.
I disagree with that statement. Depends on the aircraft. I can tell you from personal experience that the 727 with -17 engines likes to go fast. You could do the company published optimal climb which was about 300-315 kts or you could push it over and get 340-350 kts kts and get approx the same rate of climb. Being that your thrust setting is the same and the climb rate is very, very close but gnd speed is much higher it was actually more advantegous to go faster.
If I go below 280 below 10,000, it's because of severe turbulence. They'll never catch me.
Under normal ops, the 10000/250 rule still applies in Canadian airspace. However up there the CONTROLLER (as opposed to the administrator) has the authority to authorize deviations from this rule.
IE you must fly 250 knots below 10000' unless a controller specifically assigns a greater airspeed. "Keep your speed up" is not an authorization to break the 10000/250 rule. You get it a lot departing Montreal... "Climb and maintain 8000', indicate 280 knots".
ATC has the authority to waive the 250kt. restriction below 10,000 feet if there is an operational need. The "administrator" will never see a pilot's request to waive this, therefore it is handled by one of her designee's. Air Traffic Controllers are designee's of the administrator with the authority to act on her behalf in this matter if there is an operational need.
No, they do not.
Take a look at 91.117. read 91.117 (a). Now read 91.117 (b). Notice that (a) says: "Unless authorized by the Adminstrator...." and (b) says: "Unless authorized or required by ATC.........."
Just by that alone, it is obvious that the regulations make a distinction between "the administrator" and "ATC". It "ATC" and "the administrator" were one and the same, there would be no need to differetiate between them in the regulations.
If that doesn't convince you (although it should be pretty conclusive) take a look at an an Operations inspector's handbook. One of the first sections is a very detailed accounting of how exactly the adminiustrator's authority can be traced through the organization to individual inspectors. Inspectors and examiners *Do* act with the adminstrator's authority (with some limits) Even a designee, carries some of the authority of the administrator. (issuing airman's certificates)
ATC does *not*.
If you look in the ATC handbook, you do *not* find this specific outlining of how the individual controller acts with the authority of the Administrator, because they do not. An ATC controller is merely an employee of the FAA and is no more "the administrator" than the receptionist in the FSDO or a radio technician who maintains communications equipment.
An inspector has been designated a representative of the Admnstrator and acts on her behalf, issuing certificates, waivers, operating specificatons. inspecting airmen, aircraft, etc.
Don't *ever* make the mistake of beleiving that ATC can waive compliance with a regulation, except in cases like 91.117(b) (but *NOT* 91.117(a)) where ATC, specifically, by name, has been authorized to do so.
Wrong. In the language of the regulation, if it states, "Unless otherwise authorized by ATC," (or similar language) then the Air Traffic Control can provide the relief. If it states, "Unless otherwise authorized by the Administrator," (or similar language) then the only way to obtain relief is to petition for an exemption through Part 11 (which is a four-month process).
A Squared said:
No, they do not.
ATC does *not*.
Just make sure while trying to follow both of those at the same time you don't violate this one:
Section 91.123: Compliance with ATC clearances and instructions.
(a) When an ATC clearance has been obtained, no pilot in command may deviate from that clearance unless an amended clearance is obtained, an emergency exists, or the deviation is in response to a traffic alert and collision avoidance system resolution advisory. However, except in Class A airspace, a pilot may cancel an IFR flight plan if the operation is being conducted in VFR weather conditions. When a pilot is uncertain of an ATC clearance, that pilot shall immediately request clarification from ATC.
(b) Except in an emergency, no person may operate an aircraft contrary to an ATC instruction in an area in which air traffic control is exercised.
(c) Each pilot in command who, in an emergency, or in response to a traffic alert and collision avoidance system resolution advisory, deviates from an ATC clearance or instruction shall notify ATC of that deviation as soon as possible.
(d) Each pilot in command who (though not deviating from a rule of this subpart) is given priority by ATC in an emergency, shall submit a detailed report of that emergency within 48 hours to the manager of that ATC facility, if requested by ATC.
(e) Unless otherwise authorized by ATC, no person operating an aircraft may operate that aircraft according to any clearance or instruction that has been issued to the pilot of another aircraft for radar air traffic control purposes.
Avoiding "cumulous granite" would constitute an emergency, (so as to disregard the instruction) question is, would not following a speed assignment of >250KIAS in response to traffic flow or operational needs of ATC (let's say you have that 747 at 280KIAS behind you coming up and ATC needs you to get outta da way) constitues that same "emergency" deviation allowed under 91.23b.
Which rule you going to follow?
Give the controller an aluminum shower or follow ATC clearance?
I just spoke to a controller about this issue who is obviously much more informed than you people are. You need to get some firsthand knowledge on the subject versus your limited ability to quote the regs and the ATC handbook. ATC is a designee of the administrator wether you like the idea or not, they waive this restriction daily for operational needs.
Yep. Right there in FAR 1.1
Administrator means the Federal Aviation Administrator or any person to whom he has delegated his authority in the matter concerned.
I would say this to those that think "fibbing" about your indicated speed is a sport; just have a near miss, or worse, clip another airplane, or worse still, cause a fatal accident but you survive and then have your tapes pulled. A bad day in court will follow.
DC
If he thinks he is "the adminstrator" then he is not more informed that me. he is misinformed. He not the first controller to be laboring under this misunderstanding.
A couple of things:
1) If the COntroller is "the adminstratior" then why the language in 91.117? why do the specifically say what "the adminstrator" may authorize and what ATC may authorize if ATC and "the adminstrator" are one and the same?
Answer they are not the same.
If ATC can waive the 250 knot restriction anytimg they feel like why was there a special, limited time test program in Houston to allow ATC to waive the 250 knot restriction? (that program has expired and IAH ATC authorization to waive the 250 knot restriction has been revoked) It they can waive it, why the special test program to allow them to waive it?
Answer, they are not allowed to waive it, except in the limited test program which is no longer in effect.
Your buddy is most likely confused by 91.117(d) which allows the restriction to be lifted for *safety* not operational conveninece. This is in accoradance with the regulations and does not make ATC "the administrator"
Right. Now, you're missing one step there. Find where the adminstrator's authority is designated to an individual Air Traffic controller. I can show you exactly where it is written that the adminstrator's authority is designated to an individual inspector. Show me where its the same delegation is made for a controller. Bet you can't
Uhhh, you're kidding me, right? I mean this is basic, private pilot, who's in charge, what are my responsibilities type stuff. A controller can't clear you to deviate from regulations.
AIM 4-4-1a. A clearance issued by ATC is predicated on known traffic and known physical airport conditions. An ATC clearance means an authorization by ATC, for the purpose of preventing collision between known aircraft, for an aircraft to proceed under specified conditions within controlled airspace. IT IS NOT AUTHORIZATION FOR A PILOT TO DEVIATE FROM ANY RULE, REGULATION, OR MINIMUM ALTITUDE NOR TO CONDUCT UNSAFE OPERATION OF THE AIRCRAFT.
the CAPS are supplied by the FAA, That means they are trying to emphasize that information. Maybe you missed this in private pilot ground school.
There's also instructions on what to do if a controller *tries* to clear you to deviate from the regulations:
AIM4-4-1 b. 14 CFR Section 91.3(a) states: "The pilot-in-command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft." If ATC issues a clearance that would cause a pilot to deviate from a rule or regulation, or in the pilot's opinion, would place the aircraft in jeopardy, IT IS THE PILOT'S RESPONSIBILITY TO REQUEST AN AMENDED CLEARANCE.
Are you admitting that you didn't know this stuff? I certainly wouldn't, not on an open forum.
