XM Radio MyFi - cockpit questions
satpak77
Marriott Platinum Member
Guys
I am looking at the XMRadio MyFi, for use in the cockpit on long trips. I know this has been partially before, but to rehash, does it work without any problems? Questions:
1) Any problems/hiccups with the service when used in air?
2) How are you listening to it? Via earphones, or feeding it into headsets?
3) If feeding into headset, how?
4) Anyway to feed it over both crew headsets? My airplane is King Air 350
5) Any issues with Bose ANR headsets?
6) Where are you physically placing the unit? Up near the windshield?
etc
any info is appreciated
thanks
Myfi
I use mine coast to coast and Mexico up into Canada with no problems what so ever. I run mine through my ANR headset and just set the unit on the dash or I hold it in my hand because I am a bit of a channel surfer.
Hope it helps.
None, using XMWX too
Depends if I'm airlining then i use earbuds. If i'm flying I have a Y splitter with a booster so i can still hear ATC. The booster is key.
See above
Which radios do you have? I've done it in a couple of king air's i can give you an idea.
None unless you are using earbuds. You might have some weird noises till the electronics figure it out
It has a beltclip on the 90 i just hang it from the hinge for the storm window. On other airplanes i'll use the lipstick antenna on the dash and clip the unit down by my knee.
standard Collins VHF-22A comm package
I also have a cellphone adapter which connects to headset, the kind seen in the various flying magazines, for what thats worth
Yeah the cellphone adapter will work fine. If it is the one that has the headphone looking plug. I would highly recommend get a power booster if you are going to go that route.
With the collins pack you can have your avionics tech run a wire so you can plug in the myfi into the radio stack.
We used to have a 10 disk cd player in the back of the -200. It would cut out when ATC or the Intercom was on.
Probably spent a lot more time than I should have at 17.5k with 1200 for the code not talking to anyone so they wouldn't ruin the music. :)
See above
Diesel,
I have been a long time XM listener and just bought the Myfi. In our flight department we are flying Falcon 50's with Telex headsets. How can I set it up where both crew members can enjoy the myfi and listen to ATC? Any info you can offer is greatly appreciated.
DK
I've heard guys pump it through the mic switch but i don't know how it worked.
The problem is everytime you split it you need to boost the power on the myfi end because it tends to blank out the ATC and the intercom. ATC and Intercom sound like they are coming from a tin can.
Does the 50 have a Flight attendants panel or a jumpseat panel? A lot of commuter guys run it through the the third panel.
O&A party Rock
O&A party Rock
It does have a jumpseat with an audio outlet. What do you reccomend.
Please let me know so that I can be corrrrrrrrrrrrrrrrrrrreeeeeeeeeeecccccccccccttttttttteeeeeeeeedddddddddd.
Punchin out.
Put it right into the audio outlet with headphone to headphone wire. Basically a wire that has the plugin and no headsets just another plugin at the other end. It all depends on the size but it sounds like a pretty easy fix.
I'd also recomeend using the lipstick antenna and run it on the side with a paperclip in the side window.
I've got a foot thing on my foot.
Happy birthday Jimmy
Punchin out
Punchin out
Thanks for the advice.
How about a java log?
Java Log or Yellow treats made with Gorilla hands?
Ring ring ring banana phone
I've been flying the PS Engineering Audio Panel with intercom (PM7000) and stereo input jack. The front seats are wired for Bose, and I use the Bose X.
On long trips I had been bringing a battery powered CD player, and it worked good, but fussing with CD's gets old. This past Christmas I received the WiFi (sp?), and it's awesome.
With the Bose being so quiet, you can hear music through the headset as if you were home and plugged into stereo system. The XM list of channels is a surfers dream. There is always something good to find somewhere.
I use the big "desktop" antenna, and place it on either the left or right side of the glareshield up against the windshield. The Mooney has a fairly flat sloped windshield that always gets 100% reception to the southern hemisphere, but whichever side (left or right) is closer to south is where I place it. There has not been one instance of a signal loss, with probably over 50 hours of listening time so far.
This set-up takes the "long" out of trips! I hate to put it away during descent to the destination.
