TonyC said:Carry an empty 5-gallon gas can with you to the airport. (I don't know why they call those things cans when they're actually made of plastic, but that's another thread..) Before you go fly, drain 2.5 gallons from each wing into the empty plastic can. Take a Sharpie permanent marker with you so you can label the plastic 5-gallon gas can with the type of fuel. (You wouldn't want to mix up 100LL with 87 Unleaded or Diesel 2.) Put the 5-gallon plastic can behind the back seat.
You might also want to go to your state's statutes and copy the stat relevant to criminal negligence. If you think about drawing a line and that line is outside of the aircraft limitations or the FAR's, it won't be that hard for a prosecutor to convince a jury to convict.Checks said:Big D...you hit the nail on the head. I even printed off your statement about "Where do you draw the Line?" and posted it on the bulletin board at work
CHI94LA216
On July 1, 1994, at 1119 central daylight time, a Cessna 172, N7472X, registered to Dale L. Storm of Black Creek, Wisconsin, collided with trees and the terrain during initial takeoff climb from runway 27 (1,350' x 90', grass) at the Shiocton Airstrip, Shiocton, Wisconsin. Visual meteorological conditions prevailed and a VFR flight plan was filed. The private pilot and two passengers were seriously injured. A third passenger received minor injuries. The airplane was destroyed by impact and post crash fire. The flight was departing for La Crosse, Wisconsin, when the accident occurred.
The pilot stated, the winds were westerly at approximately 23 knots and the takeoff was normal. He reported that as he neared the wooded area west of the airport "...it seemed as if the wind stopped. I had no lift, airspeed started to drop." He stated he lowered the nose to increase airspeed but that the "winds were pushing down on plane." The airplane crashed in the wooded area and was destroyed by fire. The pilot stated he made the takeoff using 10 degrees of flaps and that the stall warning horn sounded prior to impacting the trees.
Two witnesses reported seeing the airplane take off "slowly" and it was "slow getting up in the air." One of the passengers stated the pilot initially attempted to take off on runway 36 (2,240' x 100') but was unable to get airborne. The pilot then elected to take off on runway 27.
cynic said:Fly naked
bigD hit the nail square on the head. The airplane will fly just fine 25 pounds over. It will even fly just fine 250 pounds over. It gets better - if it's not a Part 135 airplane, it probably hasn't been weighed recently. Since airplanes have a tendency to gain weight with age, I would be very surprised if your W&B figures in the flight manual are correct. But as bigD said, that's not the point.bigD said:The plane will fly just fine 25 over gross. But that's not the point. You'll do 25 and get away with it, and next time you'll be faced with the same question, only it's 50 pounds. Where are you going to draw the line?
TurboS7...TurboS7 said:I used to say what if you have a blow out and the airplane goes in the ditch. At that point one of my pilots said, drain the fuel, light a cigarette, throw it, and run.
Lead Sled said:TurboS7...
That technique works best if you also throw the aircraft logs and records into the fire.![]()
'Sled
