TonyC said:Carry an empty 5-gallon gas can with you to the airport. (I don't know why they call those things cans when they're actually made of plastic, but that's another thread..) Before you go fly, drain 2.5 gallons from each wing into the empty plastic can. Take a Sharpie permanent marker with you so you can label the plastic 5-gallon gas can with the type of fuel. (You wouldn't want to mix up 100LL with 87 Unleaded or Diesel 2.) Put the 5-gallon plastic can behind the back seat.
You might also want to go to your state's statutes and copy the stat relevant to criminal negligence. If you think about drawing a line and that line is outside of the aircraft limitations or the FAR's, it won't be that hard for a prosecutor to convince a jury to convict.Checks said:Big D...you hit the nail on the head. I even printed off your statement about "Where do you draw the Line?" and posted it on the bulletin board at work
CHI94LA216
On July 1, 1994, at 1119 central daylight time, a Cessna 172, N7472X, registered to Dale L. Storm of Black Creek, Wisconsin, collided with trees and the terrain during initial takeoff climb from runway 27 (1,350' x 90', grass) at the Shiocton Airstrip, Shiocton, Wisconsin. Visual meteorological conditions prevailed and a VFR flight plan was filed. The private pilot and two passengers were seriously injured. A third passenger received minor injuries. The airplane was destroyed by impact and post crash fire. The flight was departing for La Crosse, Wisconsin, when the accident occurred.
The pilot stated, the winds were westerly at approximately 23 knots and the takeoff was normal. He reported that as he neared the wooded area west of the airport "...it seemed as if the wind stopped. I had no lift, airspeed started to drop." He stated he lowered the nose to increase airspeed but that the "winds were pushing down on plane." The airplane crashed in the wooded area and was destroyed by fire. The pilot stated he made the takeoff using 10 degrees of flaps and that the stall warning horn sounded prior to impacting the trees.
Two witnesses reported seeing the airplane take off "slowly" and it was "slow getting up in the air." One of the passengers stated the pilot initially attempted to take off on runway 36 (2,240' x 100') but was unable to get airborne. The pilot then elected to take off on runway 27.
cynic said:Fly naked
bigD hit the nail square on the head. The airplane will fly just fine 25 pounds over. It will even fly just fine 250 pounds over. It gets better - if it's not a Part 135 airplane, it probably hasn't been weighed recently. Since airplanes have a tendency to gain weight with age, I would be very surprised if your W&B figures in the flight manual are correct. But as bigD said, that's not the point.bigD said:The plane will fly just fine 25 over gross. But that's not the point. You'll do 25 and get away with it, and next time you'll be faced with the same question, only it's 50 pounds. Where are you going to draw the line?
TurboS7...TurboS7 said:I used to say what if you have a blow out and the airplane goes in the ditch. At that point one of my pilots said, drain the fuel, light a cigarette, throw it, and run.
Lead Sled said:TurboS7...
That technique works best if you also throw the aircraft logs and records into the fire.![]()
'Sled
minitour said:...check me if I'm wrong here...
Take 30 pounds out of the wings and put it in the back...the airplane will still be 25 over gross, no? Just because it isn't in the wings, doesn't mean it isn't in the airplane...
Milkdud99 said:If you take it outa the wing and put it in the back seat.. .now ur 26lbs over weight (including the "can)
apcooper said:Problem has been resolved. Called the FBO and they told me that two pilots before me have booked the plane and it will be down about 2 hrs from full fuel. I will therefore be 75 lbs UNDER gross at takeoff and not only legal but safe. Since I didn't violate an regs by simply discussing the matter y'all can stop flaming me now!
As for being criminally charged that would be much more difficult than proving a pilot violated a reg. Except in very extreme cases(IE: flying drunk, threatning the crew or vanzalizing an aircraft amont other extreme actions) I have never heard of that happening in a GA plane without willful intent in the USA. Some colorful comments for sure FAN FAL! Last time I checked there was no FAR that states that it is a violation to discuss violating an FAR. Thank you.
Awsome, that wasn't that hard now, was it? Just make sure you dipstick the plane before you go and fly your plan.apcooper said:Problem has been resolved. Called the FBO and they told me that two pilots before me have booked the plane and it will be down about 2 hrs from full fuel. I will therefore be 75 lbs UNDER gross at takeoff and not only legal but safe.
It doesn't have to be extreme cases, all you need is property damage, injury or death.apcooper said:As for being criminally charged, that would be much more difficult than proving a pilot violated a reg. Except in very extreme cases(IE: flying drunk, threatning the crew or vanzalizing an aircraft amont other extreme actions) I have never heard of that happening in a GA plane without willful intent in the USA.
Standards of Liability
Civil Liability
Simple negligence is the least culpable level of legal liability. It is usually defined as the failure to exercise "ordinary care in the circumstances." Liability does not attach to such misconduct unless the negligence is a cause of injury or damages. In the aviation industry, the violation of regulations such as the FARs, and failure to comply with good operating practices or procedures, may constitute a breach of the duty to exercise ordinary care. In this regard, airline and Part 135 charter operators are held to the "highest duty of care" because they act as common carriers when holding themselves out to the public — they carry anyone for hire. Private operators on the other hand are generally held to the standard of "ordinary care."
Federal Aviation Administration enforcement actions involve a different type of civil liability. The FAA is empowered by the Federal Aviation Act to issue certificates and licenses to regulate the industry. As a result, the FAA can bring enforcement actions and revoke or suspend the certificates or issue civil penalties when there have been violations of their rules. These proceedings are administrative law proceedings and are not criminal in nature. Indeed the FAA itself cannot bring criminal charges against aviation professionals; the FAA must refer such charges to the U.S. Justice Department for prosecution.
Criminal Liability
Criminal liability is established by federal criminal statute and various state criminal laws. It is important to understand that every state has its own criminal laws, and these laws vary significantly from state to state. Further, the states are not preempted from enacting laws to impose criminal sanctions on aviation personnel who engage in reckless conduct leading to injury, death or property damage.
Hey, they're just having a little fun. Actually, I respect you for asking the question. It's shows integrity on your part. Pilots run into this all of the time - to one degree or another. Is it OK for a mid-sized bizjet to takeoff 300 pounds overweight? or an airliner to take off 3,000 overweight? (The percentages are the same.) A couple of years ago I quit a corporate job that I held for 15 years because I consistantly refused to fly airplanes that were being operated "slightly" overweight or "slightly" out of the c.g. envelope. The chief pilot's rationalization...apcooper said:Problem has been resolved. Called the FBO and they told me that two pilots before me have booked the plane and it will be down about 2 hrs from full fuel. I will therefore be 75 lbs UNDER gross at takeoff and not only legal but safe. Since I didn't violate an regs by simply discussing the matter y'all can stop flaming me now!
TrafficInSight said:You've been misled... there actually aren't any FAR's anymore![]()
We called those navigators.Publishers said:... weight you did not need on board for the flight.
Onlyflyfreight said:This guy is baiting us!!!!!!!!!
Publishers said:altitude above you, runway behind you, and weight you did not need on board for the flight.......... things most useless for a pilot.
Have the passengers hold one foot off the floor for the first 30 minutes of flight.Some guy said:Can anyone else help improvise?
Lead Sled said:Hey, they're just having a little fun. Actually, I respect you for asking the question. It's shows integrity on your part. Pilots run into this all of the time - to one degree or another. Is it OK for a mid-sized bizjet to takeoff 300 pounds overweight? or an airliner to take off 3,000 overweight? (The percentages are the same.) A couple of years ago I quit a corporate job that I held for 15 years because I consistantly refused to fly airplanes that were being operated "slightly" overweight or "slightly" out of the c.g. envelope. The chief pilot's rationalization...
"They build enough safety margin into the charts so that we can safely ignore them."
No you can't.
'Sled
Some guy said:I wouldn't go overweight. I would improvise a little though...
1. Fill all empty spaces with helium balloons.
2. Fly without the doors.
3. Does the airport have a catapult?
