Worst area for weather?
DHPFLYN
I figured this would be the best place since a lot of you fly to places around the world. Like I said just curious where the worst places are as far as weather? Are there some places always turbulent and lots of thunderstorms?
I had someone tell me that the United States was one of the worst but find that hard to believe.
Also one other question. When you are flying over the Pacific or Atlantic are you normally planned around most weather? I guess I was wondering since it's not as easy to just call call atc for a turn around weather. Or is it just that easy?
Thanks again for the information
As expected Midwest region is a nightmare in Summer when fast moving cold fronts cross the plains driving tops to 70kft and creating squall lines HUNDREDS of miles long.
I have never seen weather phenomena to compare to central USA where Pacific or Arctic systems colide with Gulf moisture and kaboom. I, as most of you have seen days with solid magenta level 4 and 5 lines from the Mexican border to past Chicago with no one getting through. Hundreds and hundreds of miles of inpenetrable CB`s. Never seen this over the ITCZ, Bay of Bengal etc.
In a book "north star over my shoulder" by Bob Buck. He was given a B29 and told to fly around the world looking for wx. After a year he said that the worst wx is in the midwest where the warm gulf aair meets the cold air from Canada. I think most agree.
thanks, So when you are crossing the pond is it easy to deviate around? or do they usually plan you around most weather? Like I said I was just more curious how it works when usually ATC plans on you being at certain points and times.
Never went all the way across, but when we fly HF meaning position reports and such we plan around the weather. It is possible to get deviations, but it may take some time so you have to plan ahead.
Some of those African easterly waves that go blasting out into the ITCZ can be intense.
But yes, I agree some of the worst wx is right in in the good ole Midwest USA.
Have done the Midwest summer and NE winter(lake effect) and while they both have challenges, SE Alaska when it goes bad, gets really bad. Bad weather, big mountains, small runways, and few options to divert. The Arctic and Kodiak can be sporty too.
Mookie
Mookie
Alaska is like another planet altogether regarding wx extremes.
I'm reading Don Sheldon's biography, "Wager With The Wind" that I picked up in a used bookstore last week. I've gotta agree, Alaska's weather extremes are amazing, and the stories of battling Denali's weather in a Super Cub... enthralling. Pick up a copy if you can find it.
The pop-up thunderstorms of the Southeast U.S. can be intense, but once you get out to the Midwest, the storms deserve some serious respect. I was battling a line of storms near Omaha in early April that rivaled anything I'd expect to see in late summer.
If you're talking about consistent severity of the weather systems..then I think the answer clearly are the midwest storms. The spring/summer CB's and the winter snow storms are all incredible demonstrations of the power of nature. That being said, although it is true that you sometimes have to deviate hundreds of miles and the only good alternate is usually 3 states away there really isn't anything to hit in the midwest and there are usually plenty of airports with big long runways if things don't work out.
As far as Alaska goes...saying "Alaska" has extremes of weather is a bit like saying the lower 48 has extremes of weather as the distance comparisons are similar. SE Alaska has a lot of small runways cut into valleys or on the side of mountain on relatively small islands. The weather rarely gets that "bad" in SE, it's the combination of everything that makes this place particularly tough.
The Arctic winter flying in Alaska can be pretty crazy as the weather is truly misreable (-40F wouldn't be surprising) and it is always dark, and the runways are always contaminated. The good thing is that most of these places are geographically pretty wide open so terrain isn't nearly the issue that it is in SE Alaska.
Then there are Kodiak, Adak, and Dutch...Sometimes I am surprised that some of these airports are served with passengers at all, let alone in the winter. These have got to be the worst operationally as they have near arctic like weather conditions with the terrain problems of SE. Although I never went to Dutch myself, that is one airport that I am glad we don't do anymore.
The worst weather in my experience is in the US central and southeast...BUT they have the best controllers hands down. Regular super cells 100+ wide in Texas with excellent vectors.
Joint second is Indian during monsoon and central Africa (anytime)? Particularly within Kinshasa FIR and South Sudan north of Jubu.
With Africa you essentially self navigate and let them now on HF when you can get them - not always.
The real stress is India, busy airspace, congested frequencies, and marginal ATC that somehow are razor sharp when it comes to you leaving their airways - nightmare.
And while we are on it ...in my humble opinion ATL TMA controllers are cream of the crop and # 1 of any controllers I worked with.
fv
Ocean flying has very specific deviation rules. Anything more than 10 miles left or right of track requires ATC coordination. As always, the trick is to put in your deviation request well in advance, as it sometimes takes ATC quite a while to get back to you. Absent that, you can change your altitude +/- 300 ft (depending if you are eastbound or westbound) and deviate as required, while broadcasting your intentions on 121.5 or 123.45 and illuminating all exterior lights.
fv
Man calling it the Indian ATC a "Marginal ATC" is actually given them way, way too much credit!!!!!!!!!!!!!!!!!!!!!!!
I was going to say anywhere in Central America in September. Going into Tegucigalpa or Panama City you're looking at CB's 24/7. Add in the occational Tropical Storm and Hurricane. Not mention the controllers down there arent overly helpful.
