When's The Last Time You Had To Hold?
January 31, 2005. KAWSE intersection on the Gland Arrival into IAH. Reason: IAH shutdown due to thunderstorm.
First time I've ever done a hold outside the training environment. I think I had to push 5 buttons on the FMS. That's a lot of work.
Holding
I have received only two real holds. One was with a student at Drake VOR in PRC in 1989. It was very simple, a direct entry to the published hold. What made it interesting is ERAU placed tremendous emphasis on obtaining EFC times for clearances and the controller did not give us an EFC time. My student received the clearance but then I piped up and asked ATC for the EFC time. A great example of applying training to real conditions.
The only other time was near MLB in 1992. My instrument students and I were returning to VRB on a clearance and a thunderstorm arrived over the field. ATC gave us a DME hold with a direct entry. Very simple.
Not that I have so much experience with holding, but I believe that ATC tries to make holding and holding entries simple instead of the complicated stuff a good instrument instructor will provide.
I held for 45 minutes while Toluca/MMTO figured out why their runway lights went out for no reason
that was a few nights ago
alternate was Acapulco so either way it would have worked out
Last year I held over ABL-NDB at 14,000 for 20 minutes also
alternate was SKCL, glad we got into destination
I probably get a hold about once every two weeks, but almost daily you can count on speed restrictions, vectors for spacing, etc.
I always wonder about the national airspace system when the following occurs: You get a delay with an EDC time on the ground. Then they slow you down enroute, then they take you off the route for spacing, then clear you direct to the "handoff fix" (I don't know the official ATC term for this, I sure some controller could inform us, but it's the fix where center will usually hand you off to the approach facility). But before you get there, they tell you "New York/Boston/Philly/etc. has stopped arrivals, advise ready to copy holding instructions". So you hold for awhile. Approach finally takes you, but before too long you're getting a tour of the Mass, CT, or PA on vectors with approach. Meanwhile, you are watching the fuel tick down ten pounds at a time, wondering exactly what you'd do if the radios go dark. I realize that complete, honest to goodness lost comm situations are rare in part 25 aircraft these days (save for the occasional "oops, I don't know how the headset audio get turned down"), but I always wonder how much mayhem would occur at center and approach if somebody was honestly lost comm going to LaGuardia.
ATL multiple times over the past few weeks. Before that, a few times on the arrivals into DFW whenever there were TSRAs, low IMC, or they were switching flow directions.
Woohoo, 3 different holds in 1 hour going into EWR today. 250 knots the whole way over from YYZ.
When I was an EF-111A EWO in England we got held in huge stack at the IAF everytime the field was IFR. It was an impressive sight. One time a friend of mine was holding in an F-111E, driving the airplane with the autopilot heading bug. The pilot pulled the throttles back just a bit on every turn. On the last turn the airplane departed controlled flight as soon as the turn started and tumbled down through the stack. The crew got out via the capsule. The whole fleet got a stick pusher mod as a result of this accident.
I got a hold in my GA airplane not too long ago. I few from Austin to Mustang Beach Airport on the Gulf Coast on a Saturday. A low stratus cloud had come in off the gulf. I called ATC and asked for IFR into Aransas Pass, which has an NDB. I got put into a stack with 3 airplanes under me, just like we used to do in England. It was my first IMC NDB approach. The weather was somthing like 400/1. I was glad for my handheld GPS.
This morning on the way into BWI. Apparently Patomac lost radar coverage, and kept everyone out. Finally made it to the PXT 023/18 and made one turn, "right turn D-> BWI."
PtP
