When to pull power back on takeoff.
Rally
Why is it that everyone I talk to get its a nitch to pull back power at 500 agl. Whats wrong with doing it at 1000 agl as long as there is'nt a time limitation (like a C-210, 2-3 minutes)? I don't see the big deal, for me it buys altitude reduces the risk of doing stuff that could induce engine problems allow you to concentrate on other stuff. Where am I wrong? To my knowledge there is no AC, Manual, Supplement that specifies that you need to pull the power back at a certain point.
If it doesn't specify to pull power back, why are you pulling the power back?
For example: I was taught in the Duchess that at 500', power goes to 25"/2500RPM...if you look in the manual, it says "climb power" is Full Throttle and 2600RPM.
Why do it if ya don't need to?
Training. That's why. Training on control manipulation. In the normal routine of flying traffic patterns, you would be leveling off at pattern altitude with the first power back, so you would skip the initial climb power setting.
Like bringing the gear up and putting it back down. For normal operations, it would be better to leave the gear down, or climb at full power to 1000', but for power change training, we do it that way.
Of course, the problem is that nobody explains that to students, so they leave the school world thinking that this is normal, and they do stuff "because they were taught that way".
When and if you pull power really depends on what it is that you're doing. If you're just using breakawy thrust for the takeoff, just to get you off the ground, then you can pull it back whenever. Typically, below 400-500' isn't the time to be pulling anything.
Sometimes I use maximum continuous power up until I reduce it when leveling off. Other times I retard power just as soon as the wheels are off the ground. In other cases, I leave the power be and back the propeller off the stops, in a propeller driven airplanes...sometimes to keep it off the stops, sometimes for noise.
Sometimes in a turbojet with the performance, I pull power rather than pitching steeply, to keep speed in check. Others because I won't be climbing far. In other cases, I hold the maximum takeoff power setting for the maximum time before reducing to max continuous...or to a precalcualted power setting.
Reduce power when and if it's appropraite, according to your needs.
On a checkride once in a sabreliner, I reduced power during a single engine missed approach, as I was turning out on to the missed course. The examiner had a fit. He wanted to know why I'd reduce power on the good engine. Quite simple, really We had too much performance, and we didn't need the extra thrust.
Reducing power may be necessary as the ram rise increases performance toward a limitation during the takeoff. The propeller that was just below redline might creep to redline, and need to be retarded. The manifold pressure that was at it's limit might need to be pulled back as the aircraft gains airspeed. The EPR that was might be creeping up with ram effect, it may need to be pulled back. The concientious operator who knows that a 10% reduction in operating temperature extends component life by 10% and more may elect to make an early reduction to save hundreds of thousands of dollars.
You decide what you need when you need it, and don't worry about it after that.
Think about things in terms of the end: You want as much distance between you and mother earth as soon as you can get it, especially in a single-engine pistion thingy, so why would you reduce the power before, say, 1000'? I also agree and used to teach to just leave the power alone until you're ready to level off in the pattern. Now, in certain airplanes, like the Aero Commanders I used to fly with geared powerplants I might pull it off a little earlier for noise and easing off the 3450 RPM just to be kind, but those things had performance like crazy, I can't say I'd do the same in something like a Duchess because, well, they do not.
Think of it this way, jets got climb performance in spades and I don't know of anyone who touches the power levers below 1000' any more(barring a short climb or something), so why would you want to reduce your climb capability in a piston single(or some light twins)when you don't have that much to begin with?
I am gonna guess the question was in the context of lighter planes, and the only reason I believe, especially with light twins, that they want you to pull the power back, they being the company instructors and business people, is to reduce wear on the engines.
I too have been chewed out, for pulling the power back on climb out, by a DE, since it wasn't in the POH, but just a silly flight school policy. It's true we do pay good money, usually, to rent these planes, why pull the power back if you really don't have to and are still pretty damn low.
WRT piston aircraft, John Deakin has written a bunch of very good articles on this issue. He also goes into the "Old Wives Tales " (OWT) that permeate our flying culture when it comes to engine management. avweb.com has these articles in their archive (you have to register).
Here's link to one of them:
http://www.avweb.com/news/pelican/182045-1.html
He generally doesn't pull the throttle off at all in the climb, but instead he leans the engine (and reduces RPM if noise abatement is a factor).
I think some folks consider him a heretic, but he backs up all of his techniques with solid data.
I've always reduced to 25/25 at 1,000'. Why mess with power adjustments so close to the ground especially when there's already a lot going on during a departure. From what I understand, most power failures occur during power changes especially ones from full power during a takeoff where you're asking the engine to do a lot from holding short to climbing an aircraft several thousand feet. Besides, it doesn't take much longer to go that additional 500'.
The myth about engine problems being related to changes in power settings in untrue. I thought I had read this somewhere, but then I read from Lycoming that it is not the case.
Correct me if I'm wrong, but don't some of the newer aircraft even tell you that full power is "okay" all the time. I seem to remember a new mooney that had that in the books. Not that I agree with the principle.
Regarding powerplant management and leaning: Lycoming says that it is not possible to over lean one of their engines at anything less than takeoff power. I've flown a bunch of big continentals, too, and we leaned them failrly hard(with only 3 failures in 20,000 hours). Got to keep these engines hot--until you're ready to shut them down. I could go on for hours, but make one power change at a time(after initial climb power change), and none within 60 seconds of each other(M.P., R.P.M, Mixture) especially in a descent. Maybe we should start a new thread for this.
Nosehair hit it on the head. It's for training purposes. Any yahoo can keep it full throtle. It requires a pilot to be in positive control and well ahead of the aircraft to perform this technique. If your are learning in a complex aircraft you are no longer an amature pilot. Avbug, as always, shared some great examples of needing to do it in "real life." Also as nose hiar said, the CFI needs to imress these ideas on the student. My biggest fear is training students who cannot fly the plane to its limits and how to stay away from the limits. Few people have told me I am going to get myself or someone else killed. The reason I do not have casualities is because even when bushing the limits I always have a safe way out. That is what students need to know, the safe way out.
I've read this several times now and cannot make any sense of it. I know it's 5 o'clock somewhere, but it's only just now 11:36 where I am.
And teaching something just to get a point across when you know it's not safe in the real world is the worst idea of the day(it's still early). Climb to 1000', level off. What is a part of any level off in any airplane? Power adjustment! Pattern work or not. So there's your "control manipulation" Retracts, too. It's a rental...mostly used for training. Cycles on the gear are the cost of doing business. "Positive climb......gear up" Just saying it doesn't count, make em do it.
That really did not make any sense, did it? I am clearly too ill to keep my mind straight so let me make it short and sweet. As a good neighbor (I always fly into or out from residential areas) I pull the props back to two thousand five hundred and often beat the landing gear on their way up. Not that I am rushed, but because I know the plane that well. I do it on almost every flight and make a cruise climb departure. I expect my students to do the same, not because it is good procedure, but sometimes it is best practice. I feel many such decisions are like authorizing a new drug. It is important to weigh the benefits against probability and severity of risk. If I needed to pick someone up and was confident that the WX would remain VFR, an INOP DG would not keep me from going.
Also concerning the comment about 'it's a rental.' Personally when I eat out, I make it a habit to not spill my meal on the table or floor. I do not stick gum to the plate or stiff the server on a tip. Even though the restaurant is making good money from my wife and me, I feel obliged to flush the toilet, wipe the counter after washing my hands and deposit the paper towel in the wastebasket. These would all fall upon the owner/operator under the category of 'operational expenses.' However, as people we need to learn to respect other people, even if they are making money from us.
Yeah so comparing flushing a toilet to not operating the engines as recommended in the POH makes sense how?
What recommended action in a POH are you referencing? I have never seen an alt reference as to when to set climb power in any piston POH. That is entirely at the pilot's discretion.
Now, pulling power back before the gear comes up (<200agl) is silly. I don't care what the airport neighbors think. They live with it and hear it all day, every day. What is 15 seconds of "tolerating" my little IO-360 gonna matter, when a 757 departed just three minutes prior?
I never care what the neighbors think. They bought a house next to an airport. Screw them until an official abtement procedure tells me otherwise, and even still that will almost always be a max percormance climb to a certain altitude or a lateral procedure.....NEVER A POWER REDUCTION AT LOWER THAN NORMAL ALTITUDE.
The point with the rental comment was that people who choose to operate more in the interest of noise and cost considerations will end up in a smoking hole. These things can be considered, of course, but "positive climb; gear up; power back" is not safe IMO. To modify an old joke, if it's being a good neighbor you're interested in: Have you ever heard the noise made by a small airplane crashing in to a house?
Sometimes the neighbors don't know what's best for them.
At full throttle the "power enrichment valve" is opened making your mixture supper rich to aid cooling. Back it off to 25" and that valve closes creating hotter temps. Nowere in a Cessna 182 POH does it sugest partial power climbs. I leave it wide open to altitude.
Fast foward to 8,000ft, full throttle won't create full power anyway because of the thinner air. Check your cruise performence chart in the POH
Lean it back to proper EGT, and enjoy the ride at 65% power and the advertised perforance numbers.
You are a pilot not an engineer, fly the plane the way the POH says to. Don't change procedures because somebody on the internet said so.
Sounds like a throw back to the presssure carb days. Still one of the best methods around when properly set up.
As far as the engineer crack, first of all I was making a point with the new airplane's manuals. I think someone's got their hand in the till with an overhaul company(kidding, sort of).
You would be correct if the powerplant maufacturers were not constantly tweaking their own suggested procedures. And I once worked for a cargo operator that had a TBO extension waiver from our FSDO on big continentals. As a matter of fact I think the thought that he put in to his powerplant management program(which allowed us an extra 500 hours on a 1500 hour engine). In certain cases I think that a full and proper understanding of what exactly is going on with your engines, especially recips, can allow one to generate very effective way of taking them on their own. Of course, not with disregard to what the manual says, but above and beyond it in most cases. I think our numbers were impressive, 3 failures/shutdowns in a little over 20,000 hours is a FINE record for a piston operator.
Besides, I don't think I made any radical suggestions to anyone about changing the way they operate, did I? Excepting the advice on flying an airplane as safely as possible given the circumstances of the question asked.
Rant over.
Sorry I really didn't mean to dirrect that crack at you.
More oriented toward the "hanger engineers" that have no clue, yet continue to spread rumors and old wives tales as though they were scripture.
cool, then I totally understand and tend to agree. I only spread rumors about my friends' wives.
What's a "big continental?" I didn't know Continental ever made any. Are you talking bout the radials? Even those were small.
Lycoming doesn't say anything about being unable to harm the engine by leanign at less than takeoff power. Less than 75% power, perhaps. But operating at takeoff power settings, especially higher manifold pressures with a mixure adjacent to lean, can damage the engine in high compression engines, thorugh detonation. Operating lean of peak, properly done, produces cooler temperatures, and does not...and lower power settings.
You don't need to keep those engines hot. You do need to control temperature change. However, leaning is really irrelevant to this topic, and isn't what was being addressed with the subject of throtle enrichment. In that case, it's a design feature to prevent detonation at higher power settings. If you've leaned for takeoff in the enrichment range and reduce power, you've leaned back too far at that point, and need to enrichen the mixture. This is applicable to carbureted engines utilizing an enrichment valve...not all do...and this isn't a function of the pressure carburetor.
You may be thinking of autorich and autolean which are entirely different functions that do apply to pressure carburetors...something with which few posters here will have had any experience.
What's a throw back to pressure carburetors?
If you're referring to enrichment, that's a mechanical fact for certain carburetion systems on many small carburetors used in light airplanes. It's a flat on the throttle cam which allows more fuel physically at full throttle, resulting in a richer mixture...the enrichment is purely a function of the physical position of the throttle.
Normal altitude could be 5', it could be several hundred feet...that really depends on what's being done at any given time. You really need to start caring what the neighbors think...it's that kind of ignorance that leads to loss of flying privileges, animosity toward airports, loss of airport properties, etc. Exercising noise abatement practices is a good professional practice...even when someone isn't forcing you to do it. Doing it becasue you are a professional, rather thann having your arm twisted is...the prrofessional thing to do.
Your cessna 185 is going to be more abrasive and annoying with supersonic prop tips than the stage III 757 for one thing...but you shouldn't be pushing your light piston single out too close to that departing 757 anyway. Do you really leave your gear down until 200 in the air? Why on earth would you do that? Positive rate, gear up. Breakaway thrust, positive rate, gear up, and any power reduction appropriate to your operation...is okay.
I have heard that sound. Have you? I also put out the burning airplane, crimped the torn and draining fuel lines by hand, and removed the battery after securing the site and pilot. What has that to do with the price of tea in china? If you're suggesting that a power reduction will result in crashing into a house, even as a joke, then you're making a ridiculous suggestion...just as you are when suggesting that making a power reuction will put someone in a smoking hole. Not so.
That would really depend on the aircraft, powerplant, and the circumstance. Operationally, even where permissible, one may have no need, nor desire to run at full power all the time.
One aircraft I flew had a standard mission fuel burn of 200 gallons per hour. However, at takeoff power, burn went to 600 gallons of avgas per hour. Remaining at takeoff power was never done any more than necessary...we liked our fuel tobe available for the mission, rather than pissing away for no good reason. Reduce power when necessary, where necessary, as your mission profile dictates. Reducing after takeoff does not mean you are going to die.
No basis exists for separating a throttle position change from a RPM change by one minute, nor a RPM change froma mixture change by one minute, nor a mixture change from a RPM or throttle position (manifold pressure) change by one minute...no factual basis at all You could start a thread on it, but it's a guesswork type of policy...a feel-good sort of thing with no grounding in reality. It ranks up there with oversquare myths, the myth that an engine fails at the fist power reduction, etc.
Dunno about the myth of engines failing at the first power reduction....but in personal experience that is when it happens the most.
2 of 3 piston engine failures were at first power reduction, 1st catastrophic with fire, second was crank failure, and 1 of 2 forced shutdowns on jet engines were at the first power reduction, technically not a failure but the problem appeared at first reduction which would have resulted in a major failure, starter generator started shucking nice chunks of metal and trying to shake the engine off the pylon (No CSD's on that model to disconnect, so shutdown was only option)
Before I left the GA/recip world, I would leave the throttles full all the way up to altitude.
Why pull them back at, I'm ready to lose the engine now altitude, only to keep pushing them foward during the climb.....
I might possibly have the record among posters here and elsewhere for engine-outs...in all sorts of aircraft and under a very wide range of conditions (most of which few here will ever enter)...and I don't think a single one of them has been at the first power reduction. Or the next, or the next, or the next...
Why pull the power back...when you might be pushing it up again? For noise abatement, among other things. If you're not faced with noise issues, then you may be reducing from takeoff power to climb power.
Bottom line, set power as you need it, appropraite with the aircraft and the mission. Not really rocket science.
I just read the article you linked on avweb. Dude said to keep the throttle full and adjust the RPM and/or mixture... or did I read it too fast...
Dude? What are you? Surfer from the third grade?
Must be talking about someone else. I didn't link an article. What's your point?
We departed today and immediately pulled the power back considerably to maintain our mission profile. What a sin. Perhaps we should have pushed the power to limits, told ourselves "self, screw the neighbors," and blown the purpose of the mission in favor of being a good flightinfo full-power-pilot...but we just didn't see it that way and went for the power reduction anyway.
In most cases, using full power to altitude would be the most noise friendly, as it gets you the most altitude in the quickest time. Might seem counterintuitive at first, but it works.
On the DC-10 out of Brussels, we use full T/O power rather than Flex. This gets us up higher faster and actually lowers our noise footprint. If we use Flex we'll end up setting off the electronic "snitches" on the departure corridor and generate nasty grams from noise gestapo.
Fly the POH.
Yes, Rez, you read it right... Avbug jumped on your case a bit too quickly this time, however Deakin's article says just that. If I remember right, he leaves the throttle full open and at about 1000' leans to 15 gph (he's flying an IO-550). He'll adjust the prop too, as required.
He dispells a bunch of techniques that most of us do regularly, showing graphs of power and heat that have me thinking about a lot of this.
He's got a slew of other articles too, so go to avweb.com and check them out.
I hope a bunch of the folks that have a lot of inline piston time (non-turbo) will read Deakin's articles, and chime in with their opinion.
Avbug, you're just my hero.
Tell me why there is no logical basis for the concept of not making more than one powerplant adjustment at once and even spacing them by a little time? M.P. adjustment= Temp change in cylinders. R.P.M. adjustment= Temp. change in cylinders. Mixture adjustment= Temp. change in cylinders.
Big is a relative term, now isn't it?(I'll hold off on the mom joke) 3 and 400 series cessnas have "big" continentals, and even the IO550s I used to tinker with on T-34s are big continentals. I know it's not big by P&W standards, but I regularly operate those, too, so I'll take the liberty.
And I've dealt with plenty of noise ababatement procedures, NONE call for power adjustement outside of normal profile(except for a few that require a reduced thrust takeoff, but that's not abnormal, either, weight permitting). If you're airplane says do that @ 5' then you just go for it. I fly jets at work when they make me go and our "mission", Ice Man, is the safety of the guy who's writing the checks in the back, then noise abatement.
Go ahead and start chopping power a a few hundred feet in you busted-a$$ rented duchess. When one of those "small" Lycomings pukes on you in the middle of the summer you will most likely end up in a neighbor's roof. I, too will ease the prop back on an R-1340 after the gear is in the well, but that's at a private airport and there's plenty of horsepower left on that particular airplane. used to do it in the twin commanders, too, as I think I mentioned, again, plenty of power. 3000 R's was go around power on those things anyway.
Pressure-carbs....it was just a little nod to the old pressure carb. Got a few hours on them myself(both wrenching and flying).....I'm totally aware of the auto-lean function.
The rest of it I'm just too disinterested to argue about, I think it's all still more than valid. Merry Christmas.
Numerous noise abatement proceedures in aircraft regard a quick climb, power reduction leveling of attitude until past noise sensors or a noise abatement area, then a return to a climb power setting. In propeller driven aircraft, this is often best accomplished by a RPM reduction, which may or may not be accompanied with a power reduction. In some aircraft, reduction of RPM just after takeoff may be accomplished for operational needs, noise abatement, or merely because it's the best power setting.
SOP in our 4Y's, for example, was breakaway thrust to become airborne, then a power and RPM reduction...the reduction was far more likely to enhance safety than any issues with the mythical but nonexistant engine-failure-with-the-first-power-reduction monster, because we were more interested in avoiding lifting a cylinder head than avoiding something that does not exist.
I do a lot of flying that doesn't climb very high...I may never climb more than a few hundred feet for the entire duration of the mission, and yes, reduction of power after takeoff, or reduction of RPM, is quite appropriate. Not uncommonly I'll back off the high RPM stops either during the takeoff roll, or just after breaking ground, while levelng at 5' to retract flaps, before climbing to 15-25' make the crosswind turn. Strange thing is, the airplane doesn't melt down, explode, or fall out of the sky because of this heretic maneuver. It may be outside the small, diminuitive box in which you operate, but it is appropriate to the mission.
Yes, mission. You fly profiles, I fly profiles. When appropriate. I am assigned sorties and missions, and they're logged accordingly. I'm paid accordingly. Perhaps you have trips, or dispatches, or rigs, or whatever you want to call them. But in every case, we each have a mission to perform, be it point to point, or some form of working operation such as utility flying. The purpose of the flight is the mission, the assignment, the duty, the plan, or whatever you desire to call it. We simply call it the mission, ice dude.
No, an 0-470, 0-520, or 0-550 isn't a big engine. A R-1340 isn't a big engine, so far as pistons go. A R-3350 or R-4360 is a big engine. Light aircooled horizontally opposed recip piston engines are small engines. As you will. Calling the engines found in a Cessna 340 or 400 series cessna "big" is worth a chuckle, though.
How would you phrase that if you weren't a college graduate?
Not that you have a need to know, but I don't rent. I don't fly a dutchess, and my butt is just fine, thanks. However, if I reduce power in said airplane, your diminuitive comfort zone would have the world believing the aircraft will come raining down from the sky...when such is a ridiculous notion. Highly melodramatic, but stupid. Never the less, you're just too disinterested to care.
Folks like yourself are the reason that places like Santa Monica are so tough on noise and are rapidly becoming restricted to the rest of us. Such shortsightedness in thinking only of yourself hurts everyone. You're responsible for the damage being done to the industry, animosity toward operations at many noise sensitive airports, and limitations that we continually face as airports are closed, arrivals and departures limited, and penalties and curfews increasingly placed by communities all over. Thanks for your help!
