svcta
"Kids these days"-AAflyer
- Nov 14, 2004
Numerous noise abatement proceedures in aircraft regard a quick climb, power reduction leveling of attitude until past noise sensors or a noise abatement area, then a return to a climb power setting. In propeller driven aircraft, this is often best accomplished by a RPM reduction, which may or may not be accompanied with a power reduction. In some aircraft, reduction of RPM just after takeoff may be accomplished for operational needs, noise abatement, or merely because it's the best power setting.
SOP in our 4Y's, for example, was breakaway thrust to become airborne, then a power and RPM reduction...the reduction was far more likely to enhance safety than any issues with the mythical but nonexistant engine-failure-with-the-first-power-reduction monster, because we were more interested in avoiding lifting a cylinder head than avoiding something that does not exist.
I do a lot of flying that doesn't climb very high...I may never climb more than a few hundred feet for the entire duration of the mission, and yes, reduction of power after takeoff, or reduction of RPM, is quite appropriate. Not uncommonly I'll back off the high RPM stops either during the takeoff roll, or just after breaking ground, while levelng at 5' to retract flaps, before climbing to 15-25' make the crosswind turn. Strange thing is, the airplane doesn't melt down, explode, or fall out of the sky because of this heretic maneuver. It may be outside the small, diminuitive box in which you operate, but it is appropriate to the mission.
Yes, mission. You fly profiles, I fly profiles. When appropriate. I am assigned sorties and missions, and they're logged accordingly. I'm paid accordingly. Perhaps you have trips, or dispatches, or rigs, or whatever you want to call them. But in every case, we each have a mission to perform, be it point to point, or some form of working operation such as utility flying. The purpose of the flight is the mission, the assignment, the duty, the plan, or whatever you desire to call it. We simply call it the mission, ice dude.
No, an 0-470, 0-520, or 0-550 isn't a big engine. A R-1340 isn't a big engine, so far as pistons go. A R-3350 or R-4360 is a big engine. Light aircooled horizontally opposed recip piston engines are small engines. As you will. Calling the engines found in a Cessna 340 or 400 series cessna "big" is worth a chuckle, though.
How would you phrase that if you weren't a college graduate?
Not that you have a need to know, but I don't rent. I don't fly a dutchess, and my butt is just fine, thanks. However, if I reduce power in said airplane, your diminuitive comfort zone would have the world believing the aircraft will come raining down from the sky...when such is a ridiculous notion. Highly melodramatic, but stupid. Never the less, you're just too disinterested to care.
Folks like yourself are the reason that places like Santa Monica are so tough on noise and are rapidly becoming restricted to the rest of us. Such shortsightedness in thinking only of yourself hurts everyone. You're responsible for the damage being done to the industry, animosity toward operations at many noise sensitive airports, and limitations that we continually face as airports are closed, arrivals and departures limited, and penalties and curfews increasingly placed by communities all over. Thanks for your help!
My friend, try reading a little.
1. yes, a noise abatement climb is a max effort climb followed by a level off and subsequent power reduction. You've now agreed with me.
2. Your engine will not fail with a power reduction(in all likelihood, mileage may vary, these are just statistics). You've now agreed with me.
3. You've obviously got a lot of mission-specific operational guidelines to follow that extend beyond what many would consider to be normal, I'm totally okay with that, but these considerations were never a part of the original conversation. My whole point has been with dealing with marginally powered light aircraft or jets. I've admitted to the same "heretic" maneuvers regarding early power reductions in aircraft that have the balls to back it up. In a sense, you've agreed with me.
4. I've never used the word "dude" on this board(caveat:that I can recall). You've got the wrong dude, dude.
5. An IO-550 is, in fact, a big Continental(and they need to be operated more carefully than Lycomings, in my opinion, so the name does matter). That cannot be argued. I never said "big reciprocating engines". By shear number of piston powerplants in the world, however, an R-1340 is still pretty big. I agree there are much bigger ones out there, but it's bigger than most and therefore relatively large. Don't know what else to say about that.
6. I never graduated from college, what's your point?
7. Okay, I'll admit: If I were in an underpowered airplane I wouldn't enjoy limiting my already limited climb performance. This makes me a bad pilot how? I NEVER said that it would cause airplanes to "rain from the sky", but it doesn't make sense to put yourself in that position does it? Once again, different in airplanes with a little guts.
8. Don't you dare give me this "folks like you" crap. I haven't flown out of anything other than private airports in recips (except for airshows) in years, and I've explained how I handle that. And I've also already told you that in a jet I play ball like I need to(even with the stage 3 noise signature). I've never been fined or been called out for busting a noise abatement procedure.
9. I said that rented Duchesses are busted-a$$, not you. Why so sensitive about it?
