Bernoulli said:
What is a "Published segment of an approach"
Question for you guys...When cleared for the approach you can only begin your descent below your last assigned altitude once you are on a published segment of the approach. My qusestion is: what constitutes a "published segment of an approach?" One of my friends says that a "published segment of an approach" only begins once you have reached an IAF. Now most approach plates have feeder routes that lead up to IAF's and they have altitudes listed on them... So are you alowed to descend to those feeder rout altitudes prior to an IAF? hey are published... and they are on the approach plate.
If the answers you get are confusing, it's probably because you've asked two distinctly different questions.
1 - What is a "Published segment of an approach"?
2 - ... are you allowed to descend to those feeder rout[e] altitudes prior to an IAF?
You seem to have already answered the first question. The initial segment of an approach begins at an Initial Approach Fix. Sounds like your friend is correct. If you agreed with your friend, I'm assuming you wouldn't have asked the question here, so it sounds like you owe your friend a cold beverage.
The answer to the second question is, "it depends." It would depend on the clearance received. The feeder route is just that - - a feeder route. It is NOT a portion of the approach procedure. If your clearance were, "Maintain X thousand until 'ABC' (ABC being the IAF), cleared YYYYY Runway ZZ Approach", then you could not descend, even if you were on a published Feeder Routing with published course, distance, and altitude information.
It is my understanding that "Maintain X thousand until established on the approach..." would mean exactly the same as above. It is also my understanding that others here disagree with that interpretation. Fortunately, I don't think that distinction is the focus of your attention, and I haven't seen that addressed in this thread so far.
If your clearance is "You're cleared the YYYYY Runway ZZ Approach" you may descend on a feeder routing.
Sounds like your friend might owe you a cold beverage, too.
