Booker
The Ladies Man
- Apr 5, 2002
172driver said:Aircraft certified before 8/8/93 are allowed to use max gross weight for certification.
The new reg begs the question...what is the most unfavorable weight? Enough gas to get around the pattern and a 90 pounder flying? Doesn't seem very standardized.
Usually it is minimum practical test weight. Reference AC 23-8 (get ready - it's 228 pages).
The FAA rationale is found in the Airplane Flying Handbook. Up to five degrees of bank may be used in testing. Reduce the weight, reduce the lift required to sustain flight. Reduce the lift required, reduce the horizontal lift that opposes the yaw at five degrees of bank. Reduce the horizontal lift produced, increase the rudder force required for a given airspeed.
Furthermore, flaps' affect on Vmca is aircraft specific.
