W & B question
Can you takeoff knowing that your estimated landing weight is over max? Is it legal to takeoff, burn extra in cruise and land within the legal limit?
In FARs I found where it's illegal to land, but I couldn't find where it says it's illegal to takeoff.
Not at all. I just think that common sense prevails rather than being caught in FAR minutia. This is how I see it working in the real world.
Flying Corporal asked if it was legal and the answer is no.
I know what happens it real world. I also know some POIs don't care until metal is bent and some couldn't figure out FARs to save their lives.
Some pilots don't know or understand a reg and may bust it by mistake. Some pilots understand a reg, but bust it anyway.
Some pilots just make their own interpretation of the regs, I love how you conveniently left out the portion that didn't make your point
Sec. 121.195 - Airplanes: Turbine engine powered: Landing limitations: Destination airports. (a) No person operating a turbine engine powered airplane may take off that airplane at such a weight that (allowing for normal consumption of fuel and oil in flight to the destination or alternate airport) the weight of the airplane on arrival would exceed the landing weight set forth in the Airplane Flight Manual for the elevation of the destination or alternate airport and the ambient temperature anticipated at the time of landing.
What is normal fuel consumption? What you would normally burn at the planned altitude? If you change the altitude/speed doesn't that change what is considered normal for that altitude? You can take off and have dispatch re compute your numbers afterwards, can you not? as a matter of fact if you choose another altitude that shows the BOF (burn off fuel) that you need from one of the choices on the burn summary, you don't even need for dispatch to re compute, take a wild guess at what that new BOF becomes, it becomes your normal fuel burn
Sorry I just don't agree with you and I have had the same conversation with plenty of FEDS in both sides of the Pacific andthey are not interpreting it like you are because how is it that the FAA, CAA don't go after folks requesting holdings upon arrival or extended downwind because they are still a little over max landing, you hear this kinds of requests all the time and the controllers accommodate your request as a matter of course, you don't see legal action taken.
You can cut in line and takeoff from a feeder, if your melon tells you to. Is it legal? No.
What do you mean, can't do an intersection departure???? If you have performance calculations Why not???
I'm glad the FAA has you to set them straight:rolleyes:
Realistically we takeoff and land routinely over and under actual the planned weight due to the fact that the pax and bag weights are averaged anyways. I would not use this as a defense in a fed inquiry or use it to takeoff illegally. This seams rather obviously hypocritical in the grand scheme of things. I remember a scenario where there was a coin collecting convention where all of the 150 bags were counted as regular checked bags at 25 lbs a piece when after a rather nose aft cg takeoff and landing was discovered that the bags were about 75 to 100 lbs. Do the math, they were way over weight. Who gets the violation here?
It seems to me that the disposition of your POI is the biggest variable.
You and I aren't really disagreeing. It's the Feds who are. And it only takes one Fed to bust you.
Do you head to Europe at all? Check out their version:
JAR-OPS 1.475 General
(a) An operator shall ensure that the mass of the aeroplane:
(1) At the start of the takeoff;
or, in the event of in-flight replanning
(2) At the point from which the revised operational flight plan applies,
is not greater than the mass at which the requirements of the
appropriate Subpart can be complied with for the flight to be
undertaken, allowing for expected reductions in mass as the flight
proceeds, and for such fuel jettisoning as is provided for in the
particular requirement.
(b) An operator shall ensure that the approved performance data
contained in the Aeroplane Flight Manual is used to determine compliance
with the requirements of the appropriate Subpart, supplemented as
necessary with other data acceptable to the Authority as prescribed in
the relevant Subpart. When applying the factors prescribed in the
appropriate Subpart, account may be taken of any operational factors
already incorporated in the Aeroplane Flight Manual performance data to
avoid double application of factors. (See AMC OPS 1.475(b) & IEM OPS
1.475(b)).
Some pilots at a previous airline were busted by a Fed who interpreted differently. That's where I get my understanding. See the top quote.
Maybe that's because before they took off, they were good with the numbers but had a stronger than forecast tailwind or shorter routing. I've done it myself.
Bad wording on my part. I meant that you can cut in line and takeoff without a clearance if you wanted. Might not have a good outcome, but you could do it.
This is just a discussion about our war stories. I'm sure the guys who got violated would like your interpretation much better, too. ;)
That's fine in real life but if something happens you need to know what the rule is so that you know what to say....what you are SAYING is a fast-boat to a license suspension if you ever have to testify about it...
what you should say is "after I looked at the fuel gauges I determined based on my quick mental math abilities that allowing for normal consumption of fuel and oil in flight to the destination or alternate airport, the weight of the airplane on our arrival would NOT exceed the landing weight set forth in the Airplane Flight Manual for the elevation of the destination or alternate airport and the ambient temperature anticipated at our time of landing...your honor.
Kinda like when you added 500 feet to your altitude to determine the bases in a base report when you were scud running VFR in a 172.
An interesting discussion, but I can't think of a scenario in which it applies.
Where I work, 121, the release has TOW and ramp weight. Ramp weight is TOW plus taxi fuel. You cannot take off if you are over your TOW on the release. You can push back as long as your ramp weight is not over the max ramp weight limitation of the aircraft.
The TOW on the release is landing weight plus enroute, alternate, and reserve fuel, but not taxi fuel.
Let's say your release TOW is 150,000 and your taxi fuel is listed as 500. The aircraft has a maximum ramp weight of 170,000. You can push back as long as you are under 170,000. You cannot take off until your actual brake release weight is 150,000. Maybe you pushed back at 150,600, but there was some fuel in the extra column on the release. You can push back, but you must burn 600 before takeoff, in this case 500 taxi and you are burning 100 of your extra.
To do otherwise requires a re-release from dispatch. They may ask you if you can burn it enroute, at which point you can say yes or no. If you say no, you have to bump payload or fuel. If you say yes, you get re-released for a higher burn and takeoff using your new release and new legal higher TOW.
How do you bump payload or fuel when your at the end of the runway and you number 1 for takeoff at LGA? You go back to the gate?
You are set up to fail when you have 45 minutes of taxi fuel and today you could have taken off without delay... After you burn your taxi fuel, you takeoff and then you get to your destination and have to hold. You end up burning your fuel and now have to divert. You sure could have used that fuel that you wasted on the ground to get yourself under a predicted landing weight to takeoff. Especially when the only limit on takeoff is your planned landing weight.
So are you saying you would takeoff at a weight that exceeds the TOW on your release? I'm saying you need to call for a re-release. You and the dispatcher can then agree to burn the extra gas enroute. If you find yourself at the end of the runway and are under your released TOW you can takeoff regardless of how much taxi fuel you have burned.
I can't think of any scenario in which you would be at or under the TOW on your release and not have burned the listed taxi fuel. You and the dispatcher can certainly agree that you can burn an extra 200 enroute to get a jumpseater on, but you have to be re-released. You can't just takeoff at a weight 200 pounds over your release weight and say that you will burn it enroute. If you and the dispatcher agree, you get re-released at the higher weight and you are legal.
What SC is saying, is that if you are released at 151,000 you need an amended release if you want to take off above that. No biggie, and it happens all the time. Fueler wasn't paying attention and put in 23,000 instead of 22,500. Amend it and get on with it.
MTOW is the lowest of the Runway, Climb, Structural, Enroute, and Landing limits (plus the applicable burn), right? I fly out of mountainous terrain and have to worry about ETCP for Enroute. The MTOW from the release accounts for all of the restrictions including enroute.
Kiwi, how are you accounting for everything else? Sure, takeoff tables will give you your runway limit and maybe some climb portion, but what about the rest? Saying you'll drop the flaps early when you get close to KDEN doesn't do much good if you're single-engine and over-weight in the middle of the Rockies.
I know we'd all like to arrive at the destination with a little extra gas, but if you're PIC and you need it, tell that to the dispatch and have them put in it the release - and make it legal.
Anybody wanna argue that you can burn reserve fuel sitting at your departure airport? Had a captain tell me that once. :nuts:
What I'm saying is that you are set up to fail by your dispatcher. Why bother leave the gate if your too heavy to takeoff? If you have to wait 45 minutes to takeoff, it's a poor plan unless your certain you are gonna wait at least 45 minutes. But I did say this earlier... If your max t/o wt due to landing wt limit is in effect. You have a certain amount of taxi fuel to get to the runway. All you have other than taxi fuel is min fuel for enroute, alt, and res. Your saying you must burn all your taxi fuel but none of your min fuel. That gives you an exact moment to takeoff. This came up alot on the crj. It was so weight limited, we were always maxed out to landing weight limit. Taxi fuel was always used in the calculation to get more weight on. I just never heard anyone waiting at the end of the runway wait while they burnt all their taxi fuel before they took off. Besides when your using wt averages what does it really matter. Have you seen the public? I'm sure we are always over weight. As long as it's good on paper, does it really matter?
No strickly speaking, it is not legal.
Only if it is reflected in the release (ie the plan), thus eliminating the problem.
Often often the final w/b will have a burn-to fuel requirement on the release, meaning you must burn down to a certain fuel value before you can take off.
You just can't say "oh we'll just burn more enroute" and call it legal, it's not.
What is considered normal fuel burn by the FAA or CAA for that matter?
Based on what parameters is BOF (burn off fuel) computed?
I'm sorry your friends got written off, when I was a kid I got written off by an inspector that said I didn't report that both propellers strike on the runway upon arrival, I was flying a Navajo Panther conversion with the Qtips, I believe your friends case would be just as easy to beat
Lets examine a few things here as to what the FAA considers regulatory compliance, (discussed with a few professional aviators now with the friendly folks at the FAA) first there is no regulatory restrictions to fly a Jet at any end of the envelope, you can take off and climb at max angle to 8,000 feet and then cruise to your destination at minimum clean speed, in the other end you can climb at VMO/ MMO and cruise at your max altitude, both are regulatory compliant and there is no violation as long as you do meet your fuel requirements. You guys are thinking in terms of what you input on your FMC and the fuel over destination that it is showing you for arrival and the FMC is not even a legal means to determine fuel requirement compliance, it is only guidance and all ICAO nations (including the USA) have the same requirement, you must use your performance charts specified in the Aircraft Operations Manual, you guys are thinking in terms of well my company cruises at ECON therefore I have to meet the requirements at ECON and the regulatory compliance has nothing to do with any speed and/or altitude, first of all ECON will be different within different operators of the same A/C just by interchanging cost indexes on the FMC, the FAA doesn't care if you cruise at .78 or .84, they don't care if you cruise at 8,000 or FL400 you guys are restricting yourself's to what you input on the FMC for your filed route and performance and the FMC is not even a legal means to determine fuel requirements regulatory compliance, only your A/C performance charts are the legal binding document.
The question came in the case that you would be a little over for the T/O to meet max landing weight (as programmed on the FMC) and Fuel Over Destination FMC calculations has NO BEARING or RELEVANCE, only your projected Burn Off Fuel specified in your performance numbers. Thus the example that was brought up (don't remember by who) You are taxing and ended up not burning all your taxi fuel before departure and ended up 1,000 heavier all you need to do is pick another performance within the broad spectrum of the performance of the airplane specified on the manuals (your release burn summary is based on that) that meet your BOF requirements without infringing on your alternate and reserves requirements and you are regulatory compliant. Don't even need a new release if you just pick a lower altitude on your burn summary, they are based on your performance charts
The only 2 people who are gonna know if land a bit overweight are the 2 pilots. There is no alarm that is going to go off and be sent to the FAA. Just use common sense.
