avbug said:If it fails in flight when you need it, are you going to climb outside the aircraft and wrap it with a screwdriver?
No, but I did get a transponder working again inflight by cussing it out. I took great pleasure in ripping out its little power supply and replacing it after landing (IAW all applicable repair manuals, repair station manuals, procedures, processes, and so on).
avbug said:(say, trying to outrun the frenzied bloodthirsty hoard in a combat zone...)
Only if they are shooting at you.
avbug said:What mechanic is going to advise you to wrap on that pump and then go fly?
Not this mechanic. And if you do that in front of me as an SOP, when it should be replaced, you won't like the result.
File a NASA ASRS form, it is a get-out-of-sanction-free form. If the action attracted the attention of the Administrator in a negative fashion, you'll still enjoy the full FAA investigative process all the way up through the full NTSB board appeal. But, when the judge smacks the gavel on the table, you'll only get the record, not the actual suspension or revocation if the violation meets all of the critera set forth by the ASRS program. If the action did not attract the Administrator's attention, it only took some time and you never know when your observations might spark an action that saves lives.
Fly SAFE!
Jedi Nein
