User546
The Ultimate Show Stopper
- Jan 24, 2004
My ignorance on the plane then! Thanks for the information!bocefus said:A High altitude endorsement is not applicable in this case as the 402 is non-pressurized aircraft.
bocefus said:The service ceiling is above 25K, but a high altitude endorsement is not required as this is a non-pressurized aircraft.
bocefus said:Unfortunately, we do not get to read into what we think it means, this is the domain of the FSDO gurus and this is one area where interpretation has been consistant throughout the country. The high altitude endorsement is only applicable when operating a PRESSURIZED aircraft.
casper1nine said:the reg is for pressurized aircraft that have a service ceiling above 25k, that is pretty plain to read. an HAE is not required for example in a p210, even though it is a pressurized aircraft. a non-pressurized a/c that can climb above 25k does not require the pilot hold a high alt. end.
bocefus is correct.
-casper
IP076 said:If you can point me to a FAA Definition of "Pressurized Aircraft" I'll take a look at it, until then, I'll go on the safe side, anything with a ceiling of over 25K like it says above needs a High Altitude Endorsement.
