"No type rating is required for non-turbojet aircraft with a MGTOW of 12,500 lbs or less."
Mostly true. Technically, LOA's are type ratings. LOA's are required for many former warbirds that are neither turbojet powered or have a a MGTOW of over 12,500.
Sure, there are LOAs for warbirds, etc....and I assumed that someone going into a C402 would have previously acquired a high performance endorsement in a single engine aicraft at some point in this training.
The guy asked a basic simple question about a 402. I didn't feel the need to go into all possibilities ad infinitem. But if you all feel the need, the floor is yours.....
OK Flx757, I sensed your sarcasm on the last post, but lets just make sure he's got his bases covered!
Does the 402 have a service ceiling 25,000 feet or higher? If so, don't forget the High Altitude Endorsement required to log PIC (of course unless you were grandfathered in as well).
You need a high performance & complex endorsement and an AMEL rating. If the service ceiling is above 25k', you need a high altitude endorsement as well. Depending on what you plan to do (passengers or freight for hire, for example), you may also need a 121 or 135 cert...good luck with THAT!
