Kingairrick
Rare user
- Aug 22, 2002
If you are above a solid layer and have blue sky above, chances are you can maintain the aircraft solely by visual reference. If you are flying a jet without, at least %50-80 of your scan inside the cockpit than I think someone needs to give you a swift kick in the bolars though! In every example I gave, there was no horizon reference. You don't need to be in the clouds to experience any number of visual and physiological pitfalls. If you go back to your instrument textbook in Chapter One, you'll find them there. Many people have flown airplanes into the water or snow on a clear day or spun an aircraft into the dirt on a clear moonless night. There are many situations where you need to put your head down and stay on instruments beyond just being in the clouds. Wouldn't you agree? That is why the definition states clearly...maintain the aircraft solely by reference to instruments not "when the aircraft is entirely enveloped in any of the FAA designated definitions of cloud-type visible moisture for a period which must exceed .01/hr"?! .... or something to that affect.Dodge said:If you are cruising along at FL330 and their is a solid layer under you from CLE to all the way to DEN, is still doesn't count as "sole reference to instruments." You still have a horizon out there. Now, I agree that you can't find I-70, but ya need to be in the clouds to be logging instrument time.
Exactly... I don't log instr time, but rather take the page total and X.05% and use that number..... the KISS methodhabubuaza said:10 % of your total time, once your flying high performance jets for a living it's 5% of your total time.
Absolutely!But we also agree that logging any time on an IFR flight plan as IMC regardless of VMC weather is total BS, right ?
Uncle Sparky said:The idea that you log every minute of an IFR filed flight as IMC just on the grounds of the type of flight plan is ludicrous.
That one is on an IFR flight plan has nothing to do with logging instrument time. The only requirement to log instrument time, in accordance with 14 CFR 61.51, is that the flight time logged as instrument time must be flown soley by reference to instruments.So you think that if you file IFR you should not necessarily log most of that flight as Instrument?
Part 61-g) Logging instrument flight time. (1) A person may log instrument time only for that flight time when the person operates the aircraft solely by reference to instruments under actual or simulated instrument flight conditions.
I mean if you are VMC but on an IFR, then that pretty much falls into the category.
Does that mean if you have the auto pilot engaged while in the clouds you shouldn't log that time?
It is interesting how the CFRs only talk about "simulated" when talking about time for a qualification.
I looked at my time and it is about 15% of my TT. That is for over 12 years of aviation experience so I don't think I am out "fat logging" instrument time.
IMO, if you are on an IFR flt plan, flying GPS Direct, Victor Airways, or etc. and this is how you are navigating, then it is Instrument time.
__________________
There should be two columns in your book for each type plus several "fill in" columns in case you feel inclined to do something like Tired Soul has done. If you meant "does my hood time count towards this magical %10", I believe the number most people are referring to is actual only. Again, this percentage is just a baseline. Some people may have much more or less. If you exceed %10 by a good bit, come employment time, some employers might be suspicious. If you fall short, your resume' may be tossed in the circular file due to lack of experience or failing to meet insurance requirements.mattpilot said:So how does simulated Instrument factor into the 10% rule? Is it included or are you guys only talking about actual time ?
I got 200 hours & 5 actual + 33 simulated (hood) + (some simulator time, not relevant).
So do i have 2.5% or 19% ?
That was the question. Thanks. I understand the entire concept - i just wasn't sure if you all counted hood time in your calculations or notUncle Sparky said:If you meant "does my hood time count towards this magical %10", I believe the number most people are referring to is actual only.
avbug said:"Hood" time counts. It's all instrument time. Refer to my previous post. There is no difference between "actual" or "simulated" instrument flight time, and the FAA doesn't make the distinction for the purposes of recency of experience or experience toward any certificate or rating.
Re-read the above postavbug said:I've worked for a number of certificate holders, and every one has cared about my experience. Perhaps you simply work for employers who lack the rats posterior to give. Even certain government contracts that have no IFR flying in them have taken a hard look at my instrument time, to say nothing of every FAA certificate holder. I wouldn't exactly say nobody cares.
I did. Each employer has asked about my instrument experience, and yes, employers do care. Each certificate holder has cared, just as non-certificate holders have cared. I wouldn't say that nobody cares...because they do.Re-read the above post
