mattpilot
Finally! Graphical TFRs!!
- Sep 30, 2003
???/?minitour said:derrrrr...I wanna be in the special olympics....derrrr
-mini
-mini
mattpilot said:???/?
flyifrvfr said:The way I teach a touch and go is upon landing flaps up. The throttle does not go to full until the flaps are retracted. This procedure prevents the student from taking off with the flaps still extended. The other reason I teach this is because if the flaps were to retract unevenly, we would be finding this out on the ground as opposed to in the air. The airplane would roll if the flaps were split.
Some skulls are thicker than others. Just doing our job, though you probably learned far more from your incident alone than from your instructor hollering at you. Bet you won't repeat it.qmaster3 said:Just want to say thanks, you guys do get it through our
(students) thick, stubborn, skulls.
