Rule #1 Neither you, nor your airplane, were ever meant to fly in ice. When was the last time you saw a bird flying with iced wings?
Rule #2 There are two types of ice protection; anti-ice, and de-ice. Anti-ice is primarily intended to prevent ice...you are primarily intended to prevent ice. Avoid ice, prevent ice. There's a connection. De-ice is designed to remove ice. Often, it cannot. You cannot. There's a connection. Therefore, de-ice is really best handled as anti-ice.
Rule #3 You'll hear rumors that ice bridging is myth. It isn't.
Rule #4 Ice and frost affects your aircraft performance more than you think it will. Act accordingly.
Rule #5 When your airplane is iced, it is no longer your airplane. It is another airplane, and does not necessarily respond to the same airspeeds, control inputs, or expectations that your former, uniced airplane did.
Rule #6 Your anti-icing equipment is subject to failure. Plan accordingly.
This is never a matter of if. It's always a matter of when.
Rule #7 Know your environment. Know what's above you, below you, ahead of you, and just as importantly, what is behind you. Never fail to consider what is behind you, and don't let something be behind you force you into having to accept what lies ahead of you.
Rule #8 On a slick runway, always slow enough on landing that you must add power to taxi clear of the runway.
Rule #9 Anti-skid is not anti-slide. Reverse may not be rearward in nature. If you don't like where you're going when you apply brakes, reverse, or any other control input, then put things back where they were when life was good.
Rule #10 You have the right, the responsibility, and sometimes the obligation to say NO. Respect it.
