Rez O. Lewshun
Save the Profession
- Jan 19, 2004
The 717 reversers won't deploy until the nose wheel is on the ground regardless of what you've done with the levers in the cockpit. Something about the big buckets coming too close to the ground with the nose in the air.
CRJ reverse thrust seemed to be pretty much useless except as a noise maker.
DoJet didn't have it...didn't need it. Big carbon brakes worked really well.
Are those of you who think it's okay to deploy the reversers with the nosewheel in the air, especially those of you with wing-mounted engines, absolutely sure you have enough rudder authority to keep it between the white lines if only one reverser deploys or spools up?
717 limitation might be a DC-9 carry over... anyone??
.....I did not know that about the B717. It is not a carry-over from the DC9 or MD80. Both versions of the DC9 type will allow the TRs to deploy regardless of the nose wheel position.
Tid Bit: SAS had a technique of flying Ref + 5 over the numbers and deploying the TRs just before touch down. This was used when landing on short, icy runways with auto-brakes and spoilers. At least that is what a couple of former SAS pilots told me.
Since TR is most effective at higher speeds... An effective way to use TR is to get the reversers configured while the TW is still up, meaning the buckets or cascades deployed. Once the nose wheel is down then increase the thrust from idle. This way one is not wasting time waiting for the NW to derotate as stopping distance is reduced....
What is really comes down to is policy. Otherwise it is just technique...
