The Russian
  • Thread starter Thread starter Wiggums
  • Watchers Watchers 20
WTF - shutdown both engines just prior to touchdown - PLEEEZE
Go back to the GA board - to say that shutting down both engines in the flare with 74 passengers on board because of an Unsafe gear indication is "proper technique" needs a Form-5 checkride NOW!
Sorry, posting on a message board about correct technique is not grounds for a "Form-5".
First - a DHC-8 400 is an Electric airplane - YOU CANT JUST SHUT the engines down and work everything else - BAD THINGS HAPPEN in electric airplanes when you suddenly turn off all the 28volt juice.
Wait, I thought it was a hydraulic airplane? Can't you guys make up your mind? Show me where the battery doesn't connect to the electrical system. It will, and that will give you electrical power when you shut down engines.
Off the top of my head - Fire Detection
Wel, you can't get enough of that.
- Anti-Skid Braking system - Normal brakes
It's not down (gear), you won't need them. Ground friction.
- Ground Spoiler activation
This can only hurt you by increasing drag and putting pressure on the gear during roll out. You want to apply the weight witha smooth technique.
- Cabin lighting
You have emergency lights.
- Roll Spoiler (so much for all the cross-wind correction you had).
You don't have ailerons? If I am rolling out with a gear that is not secure, I do not want any additional drag on the wing as I am trying to keep it off the runway until the last minute!
Not to mention you just took away the best way to slow down a turbo-prop - reverse.
You will not need this in the emergency landing phase. You will be skidding. If the gear holds, use aerodynamic and emergency braking.
I am guessing that in the flare the prop would be in Flight-Beta (Electric control?) which would really make it a mystery as to what would happen if you suddenly shut the engines down.
It won't feather first? What kind of Dash (let alone turboprop) are you flying? Even if it fails flat, you have the option of feathering first.
Second - you are going to take two 14 foot diameter (I'm guessing +/-) propellers and take it from min (high drag) through max (low drag - with a nice little kick) and then to feather ( no drag) at 10 feet with each engine acting at split second intervals to the other - not quite at the same time - at a low airspeed.
Simultaneous feathering. Grab both controls and feather. It is very simple. It will happen so fast that you will never feel a change in the aircraft until the feathering is complete. Then you compensate for the change. You are a pilot, you can do it I am sure of that.
You will be all over the place - and being that no pilot has probably ever performed this aerobatic maneuver before in his career to that point - probably going to really F !_! ( K up the landing and hit really hard So IF the gear does collapse there will be a big question if it would have collapsed anyway had you just followed the procedure.
Maintain directional control. It's easy.
Additonally - ask any 400 driver - you DO NOT REMOVE POWER until the wheels are ON THE GROUND or you pay the price.
Adjust your technique to prevent this from happening.
Third - I realize that you have an "emergency", however I submit that there are different degrees of an "emergency" just like you can crap your pants or you can have explosive diarrhea in your pants. One is definetly preferable to the other. So Ms. Yeager - you shut two of your engines down on your Dash 8-400 and suddenly a gust of wind blows and now you are too high and drifting way left and you need power or the student pilot in a 152 doesn't hear the tower yelling at him to hold short of the runway and you need to go around - now what? You just took a semi-big deal emergency and got yourself into a situation where people ARE going to die.
Wrong. The time to feather is when you are committed to land, in the flare, if not already on the mains. Stabilized approach. You are obviously misunderstanding what I am saying. I am NOT saying to shut it down even as far as over the numbers. If you are more than 5 feet off the ground you are too far from the runway to shut the engines down. Have you never seen this done?
Additionally - you do not KNOW the gear is going to collapse in this situation - yes it's unsafe - but is it a bad computer - bad prox switch - If you do this procedure the gear BETTER collapse or your career is over.
Why? Your career would not end for attepting to be safe. You have the right, as the Captain, to do what it required to meet the extent of the emergency.
I've had to stop on the runway and have mx come out and pin/inspect the gear because of a faulty indication so it isn't unheard of, I would even bet somewhat common.
Huh? So have I.
The way I see the two SAS events is that with the exception of the initial failure - everything worked as planned. Yes the prop piereced the fuselage but it didn't puncture it in a place that injured anyone. The 1/2" Kevlar shield in the plane of the the props kept anything from penetrating where somebody would have gotten killed. No fire from impact. This happened twice - with presumably the same procedures used and in both cases nobody got killed.
People got hurt. Some seriously, as a matter of fact. There was a fire, watch the video again. The right engine has black smoke coming from it. This aircraft DEPARTED the runway at an unnecessarilyextremely high velocity for the situation.
Sounds like that at least as it relates to the QRH procedures used - it's a slam dunk success story.
Airplane is totaled, passengers injured. Not a success.
This "shutting down two engines" BS is from the flight school operators/135 bosses/owners trying to keep there engines from getting trashed. I know it has worked for some people (they saved the engine) but it isn't something that I would ever do in an airline operation under these circumstances.
Read your FAA material. Screw the engines, just don't let the props kill anyone or cause you to lose control.
Well, I really didn't expect this type of reaction from my post. I can agree with you guys giving me a hard time for "Monday morning QB'n", but this is ridiculous. You must do what is nessecary to meet the emergency. If shutting down the engines is going to make the overall outcome safer, then you should do it. In the case of the SAS crash, things could have gone better.
I agree with the masses.
Follow the QRH. Maintain aircraft control and the accident will be survivable regardless of what you do with the props.
Igneousy2 is totally correct. I speak from experience since I had to land the mighty SAAB twice with a red light on one of the mains. Nowhere in the checklist did it say to shutdown both engines. Specifically for the reasons cited by Igneousy2. It did however have us move passengers out of the seats near the prop arcs which we did. Granted I never flew the stretch King Air or E-120 but my experience with the SAAB and ATR's is if you grab both condition levers and slammed them into feather and shutoff at the same time the props would not match each other in movement.
As far as shutting down an engine inflight to save fuel. There are times and types of aircraft where this is an appropriate procedure. Just ask the passengers on that AirTransat glider if they wished the CA had shutdown that engine.
Bottom line is if you start making stuff up outside of the QRH you will get hung out to dry at the hearing.
Mach, a few questions:
1. What if you couldn't move passengers? i.e. a full boat of pax. Would it be an "oh well the QRH doesn't say to feather so good luck to those guys"?
2. Why wouldn't they feather at the same time? Even if they did, they couldn't be noticably that different. Have you feathered both in either aircraft while in flight or in the sim?
Depending on the situation. Right cicumstances, right decisions. Always lean on the side of safety of course. Viper asked me earlier and I responded no. If he would have specified the circumstance, I would have given him an answer that would fit the needs of the emergency keeping overall safety in mind.
On the other hand.....
Just to solidify my point, where in the QRH does it say to shut down one engine to conserve fuel? I'm am absolutely shure there is not one that suggests it. There is too much liability. Is it the right thing to do for the situation you describe?
Yes.
But it isn't in the QRH.
So why would you shut an engine down to save fuel in a min fuel situation?
Russian, unless you can provide some engineering credentials on the airplane you fly, get off your high horse thinking you can rewrite the manuals or checklists. granted, there is no substitute for pilot judgement in the rare circumstance that the manual doesn't cover a specific malfunction. there is also no substitute for knowing a pilot will adhere to published guidance in an emergency. i would never let my family fly on any airplane on which you were the captain.
there may be the outlying and extremely rare reason to deviate from manufacturer guidance. why would this be one of them? i've never flown this aircraft, but don't you think the engineers foresaw this eventuality, and wrote the checklist so jackass pilots like us would not have to second guess it when the time came?
news flash: you're not as smart or experienced as you think you are.
let's get this thread off the majors forum and over to where it belongs.
First off - maybe my standards are a little lower than they should be - but in an emergency, the damage or lack of damage to the airplane after the emergency is so far down the list of concerns that in a big emergency I probably don't even think about it.
I am actually starting to understand where the russian is coming from a little bit -
When I was working my way through my ratings the only way to experience Airline Ops was to read NTSB reports - air crash books - etc.
When you read those kinds of things you read - unsafe gear - plane departs runway - crash, cargo smoke light - plane errupts into flames - crash. Circuit breaker pops - recirc fan frys - crash.
What happens when you really get on the line and can only learn through experience is that the VAST MAJORITY of the time you have a warning light on NOTHING HAPPENS. If the gear DIDN'T collapse on these airplanes we would not be talking about it today. Now before I get jumped on I am not saying not to follow the procedures and assume that the gear is unsafe. But the response you do make can't cause more problems then you had to begin with - Like the doctor saying says - First, DO NO HARM.
So when you are just starting out - you see a red light and you think Oh my god the gear is going to collapse when we land! The senior CA sitting next to you's first thought is - damn it we are going to be late to the hotel.
I am for getting creative in an emergency - but the procedure you describe is so far out of the norm that I think you are creating a more dangerous situation by the maneuver then the unsafe gear itself poses.
I think the most creative I would get is to land on the safe gear and hold the unsafe gear off as long as possible - but not so long as I lose control of the unsafe gear's descent rate - to get as slow as I could before any potential collapse. But I think that's about it.
You are always better off crashing slow and in control then fast and out of control. I think anything that works against that should be avoided.
I am not sure what FAA publication you are speaking of as I didn't read through the thread that this one is a branch of but - every one I have ever read hardly speaks of flying techniques and procedures applicable to transports.
AND how do you know nothing is gonna happen?? Complacency kills!!! I treat all lights the same way-acknowledge the prob, asses the situation, use all my resources, and fix the problem. And if nothing does happen, great-and if it does, Im ready!!! Common sense goes a long way. :beer:
The DC-6, when it is light, as in almost empty, will burn less with one shut down. If you're at or above MLW with one shut down it will gulp fuel like it's going out of style. The reason for this is that at higher gross weights on 3 engines the power you need to maintain above L/D max is above the power setting at which you may lean the engines, (normal cruise operation we lean well Lean of Peak) resulting in a really poor brake specific fuel consumption. If you shut one down on a loaded leg, you can pretty much forget about continuing on to destination and diverting to your alternate.
Back in the 60s JAL routinely shut down two engines on the 707 on their Tokyo-New York City route. This was discover by Pan Am, because no matter how they tried Pan Am could not do the same route non-stop, stopping at PANC for fuel. So they put some line Pan Am pilots on the JAL flight and they figured it out. A friend of mine was one of the Pan Am pilots.
The FAA was not amused.
Both the Falcon 50 and 900 under certain conditions can increase range by running the number 2 engine at idle. Not that I have even done this you understand.
Now, shutting down both engines on a turbo-prop before touch down can be viable depending on the type of engine and aircraft. Such as a King Air it would be a good idea. On the other hand in an MU-2 it would be attempted suicide. (Actually it would be suicide.)
What a bunch of rats!
@moderator,
Why has this thread been moved and why has my post been removed. My response to the topic starter was to keep it civilized and to respond to content and not the person as it was obviously a personal attack to the russian after his comments on the dash incident.
