Skywest Pylot:
The place to start cleaning up is your own house. How many times have SkyWest pilots failed to vote a union on the property? How many of ASA's jets do you operate due to aircraft transfers while ASA was trying to raise their compensation and work rules? How giddy were your fellow pilots when upgrades were 6 months at Skywest and 5 years at ASA? How do you like SLC, and ATL bases?
SkyWest should move beyond the Student Counsel and get a union.
You may have moved on, but the problem at the regional level remains the same. They do not own the brand. As long as ALPA allows the outsourcing management will get the work done by the lowest bidder. I like some of your ideas, but coming from a "SkyWest Pylot" it seems hypocritical in the extreme.
Unfortunately, the SkyWest Pilots refuse time and time again to unionize. The merits of ALPA are not good enough to get the SkyWest guys to take the plunge.
Horizon is not flying a bunch of 50 seat gas guzzlers (by CPSM standards). Correct me if I am wrong but isn't Horizon getting rid of their RJs and going turbo prop? (Q400) IMO, other regionals should be doing the same.
Now this is something I don't understand, and it really doesn't have to do with the subject of this thread. Why is it that Skywest has attempted to unionize under ALPA? Isn't ALPA the same union which "supports" most of Skywest's mainline affiliates? Wouldn't ALPA shaft Skywest in some cases because both them and the mainline affiliates are under ALPA contracts?
Does anyone think Skywest would be better off with a different union altogether, one that will fight for their rights, not a mainline carrier's rights?
Just a thought. . . .
Nope.Wouldn't ALPA shaft Skywest in some cases because both them and the mainline affiliates are under ALPA contracts?
With Aloha's demise thanks to higher fuel and Mesa, it shows that some routes can't be flown profitably with certain aircraft. Their 737-700s flying from the mainland to Hawaii just weren't cutting it with high fuel, and they needed larger planes to lower the CASM. How are your 738s doing to Hawaii by the way? You ANC guys still get to fly those, right? That must be awesome. Are you guys at Alaska getting any larger planes than the 739?
Bye Bye--General Lee
You have the right idea, except that those travelers need to connect. With the multiple options travelers have from any given city, what they look for is convenience. Minimum connection waiting times, cheap flights that don't leave at 6:05 in the morning or get in at 11:59 p.m., etc.Exactly! This is an example of right-sizing. Why put multiple 50's on a route that can be covered by a 737 with adequate frequency.
True. This is why 70- seaters are more economical on many routes than a 737-700 or 800, not to mention that a 40 minute flight from ATL-JAN (Jackson, MS) is a waste of a 737's resources unless you can fill it up with $700 a piece tickets.Not sold on that assumption but do disagree on routes short enough that the altidue necessary to match fuel burns won't be reached long enough to cruise.
There ya go! NOW you're starting to piece it together. One word sticks out in that sentence you need to think about again: YIELD.I disagree here. Somewhere in the spectrum of markets, there are shorter routes that have little competition that can produce enough yield per ticket but not enough tickets to fill larger aircraft where the 50 will beat the economics of a 737.
You are correct. ALPA needs centralized leadership and a way to resolve disputes between MEC's in house. ALPA needs one position, one agenda and one voice.Unfortunately, the SkyWest Pilots refuse time and time again to unionize. The merits of ALPA are not good enough to get the SkyWest guys to take the plunge.
The carrot failed. It is time to try the stick. The only stick big enough, as far as I can see would be something along the lines of only union carriers doing feed for union mainlines.
All that said, the unions, on a national level need to come up with a better strategy at contract time.
sorry andy, but u r wrong. Fuel burn on a 737-800 is the same at altitude as a CRJ 700. we carrry 157 pax, and a bunch of cargo that an RJ couldn't possiblly hold. CASM is what the game is all about nowdays. I'm betting the days of fee for departure are over for any regional contract in the future. Unfortuantely SkyW will not be able to count on those cushy preset profit margins that they have been able to in the past. much to the delight of pax, the aircraft will get bigger.
Mookie
This assumes you can fill all the seats.....if you are driving around in your 737-800 at a 60 percent load factor, you can't be as cost effective as a CRJ-700 with a 100 Percent load factor......acquisition cost also comes into play, weight based landing fees, etc.
what happened after 9/11......demand fell, and RJs began thriving as there wasn't demand to keep mainline aircraft on many routes, but RJs filled the void......its happening again as mainline aircraft are parked with no replacements in site
Actually, more replacement jets are being parked than mainline planes this time around.what happened after 9/11......demand fell, and RJs began thriving as there wasn't demand to keep mainline aircraft on many routes, but RJs filled the void......its happening again as mainline aircraft are parked with no replacements in site
Fins, no need to slam Skywest Pylot. I have known him for some time. You will not find a more vocal person trying to get his pilot group while he was at skywest to do all that he suggested with his first post of this thread and what you say above. He was part of the solution, not the problem. Dont get the two types of pilots at skywest confused. The majority are koolaid drinking, cancer producing lackeys. Skywest pylot was one voice going against the grain and eventually gave up when noone would listen....he moved on.
Anyone wonder why ALPA is a failure?
Hey sedona, maybe you can threaten me or tell me a really scary story of someone getting fired every week too.
What does Broken ALPA koolaid taste like?
W
