Taxi Lights for Daytime Taxi
Hi!
If you are on the runway, and your landing lights are on, most other planes (and ALL the airliners) will assume you are rolling for takeoff and will take appropriate action.
I like to do stuff the way the FAA requests...
cliff
NBO
Our POI is tell us to use only strobes when in position and holding, landing lights and taxi lights on when cleared for take off. That way aircraft crossing down field can tell when you are rolling. Makes sense to me, since it is hard to tell the difference between Taxi and Landing lights on some aircraft.
I wish I could turn the Nav lights on on the Learjet 45 in the daytime, but when we do that the switch indicators all dim and you can tell if a switch is on or off.
Wow! That's the dumbest thing I have heard in a long time. What was Bombardier smoking when they came up with that? I'm glad it did not carry over to the Challenger 300. Is there a service bulletin to allow use of the Nav lights during the day or are you stuck with it?
I am told something is in the works. All we need is a bright dim switch. We also have to turn on the Left side instrument lights for the APU ampmeter to illuminate.
9/26/03 AC 91-73A
10. USE OF EXTERIOR AIRCRAFT LIGHTS TO MAKE AIRCRAFT MORE CONSPICUOUS.
a. General.
(1) Exterior aircraft lights may be used to make an aircraft operating on the airport surface more conspicuous. Pilots may use various combinations of exterior lights to convey their location and intent to other pilots. Certain exterior lights may also be used in various combinations to signal whether the aircraft is on a taxiway or on a runway, in position on the runway but holding for takeoff clearance, crossing an active runway, or moving down the runway for takeoff.
(2) Because adherence to the guidelines in this AC are voluntary and aircraft equipment varies, pilots are cautioned not to rely solely on the status of an aircraft’s lights to determine the intentions of the pilot(s) of the other aircraft. Additionally, pilots must remember to comply with operating limitations on the aircraft’s lighting systems.
b. Exterior Lights. To the extent possible and consistent with aircraft equipage, operating limitations, and pilot procedures, pilots should illuminate exterior lights as follows:
(1) Engines Running. Turn on the rotating beacon whenever an engine is running.
(2) Taxiing. Prior to commencing taxi, turn on navigation, position, anti-collision, and logo lights, if available. To signal intent to other pilots, consider turning on the taxi light when the aircraft is moving or intending to move on the ground, and turning it off when stopped, yielding, or as a consideration to other pilots or ground personnel. Strobe lights should not be illuminated during taxi if they will adversely affect the vision of other pilots or ground personnel.
(3) Crossing a Runway. All exterior lights should be illuminated when crossing a runway.
CAUTION: Pilots should consider any adverse effects to safety that illuminating the forward facing lights will have on the vision of other pilots or ground personnel during runway crossings.
(4) Entering the Departure Runway for Takeoff. When entering a runway after being cleared for takeoff, or when taxiing into position and hold, pilots should make their aircraft more conspicuous to aircraft on final behind them and to ATC by turning on lights
that highlight the aircraft’s silhouette. Strobe lights should not be illuminated if they will adversely affect the vision of other pilots.
NOTE: The SOP of turning on landing lights when takeoff clearance is received is a signal to other pilots, ATC, and ground personnel that the aircraft is moving down the runway for takeoff.
(except landing lights)
(5) Takeoff. Landing lights should be turned on when takeoff clearance is received, or when commencing takeoff roll at an airport without an operating control tower.
Unfortunately that 'dimming' issue is true on the Lear60 as well-- so while we would like to standardize, we do the closest thing.
I agree with G200. Ice lights and strobes on when crossing a runway--any runway (unless it's got big yellow "X's" painted on it).
TC
Hi!
Thanks for the AC on lighting, above. I have read/done all the FAA/AOPA materials/online educational publications on airport movement safey and they all say about the same as the AC pasted above.
cliff
NBO
What do you guys think about turning off taxi lights at night when holding short? Some guys say it helps landing traffic see the runway because they're not staring at your bright lights, other guys say leave them on so the landing traffic can better see you. I can see the point about being seen but I can also see the point used in the AC of not adversely affecting the vision of other pilots.
PS I hate some of the new GA planes that only have strobes and not a separate rotating beacon. They always blind me rolling down the taxiway.
Hi!
We always do: Taxi ON for movement. OFF for stationary.
cliff
NBO
I think its great practice.
We never use strobes on our Cirrus (no beacon) at night on the ground due to the destruction of night vision for us & other folks; the HID landing light & nav lights are plenty for folks to see and avoid us.
It'd be nice if more flight instructors would emphasize this technique to their students; lord knows I was one of the few who taught it when I was instructing at Purdue (their Warriors have strobes/no beacon).
Yep. Always. The BS about "wearing it out too soon", how ghey. Old school old timer. Aviation is so standardized (beacon with engines fired up, Nav with APU/GPU, etc), you'd think people would want to let others know. Next thing you'll hear is that they don't jump all over the brakes when the mains touch!
I hear you on the radar thing. Flown with plenty who don't know the radar is gyro stabilized (in Standby), so when it wasn't being used, "OFF" which always equaled a CLUNK! We'd be taxing in and they'd wonder what all the loose avionics equipment is up front clanking around everytime we made a turn.
I don't run the radar unless I need it. If I'm not using it then it's on STDBY. I get enough radiation as it is so I figure every bit I don't get exposed to has to help over a career. (Kinda' like soaking pizza grease up with a napkin before eating it--I see people do it and think, "Maybe it is worth the effort when you consider eating greasy pizza over a 50 year period.")
Not worried about wearing it out as much as I am getting some kind of exotic radar/cosmic radiation/bad diet-induced cancer.
LOL
At the very least they should be turned off when there is another airplane holding short across the runway. I have seen pilots at multiple airports insist on keeping their taxi lights on while holding short at night despite facing the cockpit of another plane sitting across the runway.
remember there are aircraft specifics here, on a lear 45 for instance if you have the nav lights on during the day it dims the gear lights just like in a piper arrow ! so cant use them, but you do use them on a gpu/apu situation on the ground as the logo lights turns off when the aircraft is running on battery power ie the gpu/apu goes offline and you are outside the aircraft.
but for taxi sop is taxi lights and recog on, cleared for taxi off and land, landing lights on , and on approach, when cleared for the approach turn the taxi lights on to remember you are cleared.
I love it when the plane across from you at the hold short turns on their lights at night when cleared into position before making the turn onto the runway. Zing! Night adaptation? What's that?
:D
Aircraft in movement TX light ON then OFF stationery.
Crossing Rwys All lights go ON
Clear into P & H.. TX light ON and I/C light ON (No strobes here yet) I hate people doing this specially at night!
Clear for T/O All lights go ON
Depending on the Sector FL180 or 10K Pulse lights go ON
Clear to land all lights go ON
Cleared off Rwy TX light ON
P&H strobes (and everything but the land lights) should be on. Many have been killed by getting hit from behind by landing traffic that didn't see them..
You have a point here. But while all those lights mean something specific to you, when I get a crossing clearance downfield your lights just confuse the shattner out of me. I don't know if you're coming or going. How about taking the P&H clearance but put yourself offset both the centerline position and angle. Then throw on those logo and wing inspection lights. In the daytime being someplace other than in a white plane on a white centerline should make you a bit more recognizable and the same position at night with the aforementioned lights might do the same trick. The with a takeoff clearance illuminate the forward looking lights and strobes.
I'm not sure why it's confusing to you. It's most likely exactly what your SOP is in your 76. Do you offset the centerline when in position?
The danger is getting hit from behind by a landing aircraft. It's happened twice that I can think of off the top of my head. (EMB @ LAX and King Air IN ATL)
I flew with a Viper driver who told me about a guy plowing through a T-38 because he didn't see him due to the "centerline stripe camo pattern." Having heard that tale of woe I make a point to offset a little bit anytime I'm on a runway for an extended period of time, be it position, back taxi, or a long rollout.
