Taking PVT written tomorrow
cforst513
Giggity giggity goo!!!
ok, what's your advice? what should i take with me besides a bunch of pencils, paper, and an E6B? Anything else come to mind? Also, how bad is this test?
If you've looked over the test questions you wont have too much trouble. The big advice I can give is RTFQ, RTFA (Read The Freakin' Question, Read The Freakin' Answer).
Like any multiple choice test, if you get stumped, start by eliminating the obvious wrong answers.
You won't need pencil/paper, the test moderator will supply it for you. E6B, whats that?! :D Anyway, also bring a calculator that YOU are comfortable with. Even if it does have memory, like my TI-83, if you clear it in front of the MOD, they should be happy to let you use it. Lastly, get some sleep and avoid the beer this evening (I made that mistake before my Commercial Written).
Yes, RTFQ, RTFA........ And relax. You had a book to study from with the ANSWERS in it. Not too too teribbly hard.
HAVE FUN
gkrangers said:
If you don't get atleast a 90, your an idiot. :)
And after so many people make this mistake and are corrected for it on this forum...if you STILL confuse "your" and "you're", then YOU are the idiot.;)
Relax. Take a few minutes once you sit down to take some deep breaths. Then read the questions carefully. On the plotting problems take your time and make sure you are reading the correct numbers. On the PVT test the answers are far enough away from each other so that the correct one will be pretty obvious once you work it out. And good luck!
Test Taking
All good advice, however there is one more piece of advice. When you get to a question and you are not 100% certain of the answer, generally the first impression is the one to go with. Do not try to over analyze the question. The FAA is big on verbage that may trip you up. Only one answer IS the right answer (though more than once we old timers have found a mistake or two).
Good luck and for Gods sake, build some more time.
lol, aeronautic, i'm at 38.5 hours, i'm in the clear.
unfortunately, my test was bumped back to saturday because they could 'only' give me 2 hours instead of the full 2.5 hours. unreal. i was upset. i told them i would sign something that gave them permission for me to go w/out the 1/2 hour, but nothing doing. besides, the lady seemed a bit.... stressed when i talked to her, so i decided to stay on her good side.
so here goes the new schedule: in-house prog check thursday, written saturday, and hopefully checkride in the viscinity of sunday-tuesday. thanks for the kind words (and cheats, you rock mini, i'll do just that exact pattern :D) from everyone!
It's nothing at all. Took me all of 1/2 hour, and got a 95. You will need nothing more than a plotter, calculator, and possibly E6B. If you've been studying, there answers to the questions will literally pop into your mind. Be careful on those performance charts though. The insanely small lines can trip you up, and you may get an answer that is pretty close to a false one listed in the choices.
By the way, my insturctor told me a little detail that I didn't expect. He said you were actually better off not getting a 100%, because if you do, the examiner evaluating your checkride will tend to break your balls, and expect you to know EVERYTHING.
I got a 100% and my PVt oral lasted all of about 25 minutes...Basically the flight planning part. Almost no other questions, and his comment was if you got a 100 on the test we don't need to sit here for 2 hours, lets go fly.
Probably to help rationalize in his own mind a plausable explanation as to why HE didn't get 100%.:rolleyes:
