And that Boys, is what ATC has to deal with!!! No wonder they hate us. It seems we have no idea how to fly our airplanes at busy airports with other airplanes right behind us.......Hey Howard, they won't clear you for the visual while on downwind. They tell you "expect" a short approach. That doesn't mean Slow down!!! In ATL, or any other really busy airport where they put airplanes tight in trail, when you slow down, you just caused compression with the guy behind you. Again, they CANT turn you until you are below 5000ft at ATL due to a three runway landing configuration. While your busy slowing down to REF and causing compression behind you, you should be decending in order to be turned in to get your gap. "Expect" a short approach does not mean slow down!!
First, settle down before you pop something. All those exclamation points are making
me wince.
Second, that's not what Howard said at all. Your reading comprehension blows.
You implied that "going fast" was the best or only way to be able to get down in a hurry for a "short final," regardless of the length. He pointed out that was crap, and explained, that at a
hypothetical airport,
IF cleared for a visual from downwind, then dirtying up first will get you on the ground sooner, contrary to
your assertion. He
never said that one shouldn't follow ATC directions or that they should just do whatever they want. Nobody on this thread has
ever said that, despite your implications.
Next, it appears that the only large airport that you know anything about it ATL. Good for you; now that you work for SWA, you'll see more large and/or busy airports, assuming you don't stroke out first. Guess what?--they all have their particular idiosyncrasies. And the answer isn't always, "go fast!!!!!!" (Did I put enough exclamation points in there?) Is there a learning curve at a new airport? Sure there is. ATC notes issues they find with new entrants, and management puts out memos to ensure all the pilots are aware of them. Pretty much like at every other airline.
Also, despite what's rolling around in what passes for your brain, it turns out that actually, ATC
doesn't "hate SWA." I know; shocker, right? They don't "hate RSW across the board," they are not "fed up with SWA," and they haven't "given up on a 6-8 mile final" for Southwest. If you actually pay attention and ask someone other than another pissed-off FAT guy, you'll find that overall, and nationwide, Southwest has a very good reputation with ATC. And this part may also come as a surprise to you, but the average ATC controller
doesn't share your SLI angst,
doesn't really care if you wanted to be bought, and
doesn't blame SWA, SWAPA, or RSW pilots for all the woes in their life. By the way, are you related to FreightdogFred? :angryfire
And finally, "your" is a second-person possessive pronoun. "You're" is a contraction of "you are." There's actually a difference. Hey, maybe you can get someone at Atlanta ATC to explain it to you. :blush:
Bubba
