CookieMonster
Active member
- Sep 1, 2003
If you get to the sim and recite that as "Throttle closed, start lever cutoff, fire handle pulled" I don't think anybody's going to scream at you. Get the right steps in the right order, don't worry about letter-perfect. HPA has a slightly different outlook than the Air Force did about such things. At least, that was the approach a couple years ago there.THRUST LEVER CLOSE
START LEVER CUTOFF
ENGINE FIRE SWITCH PULL
Here is a little tougher question about the 737 Type for our SWA pilots from a SWA wanna-be:
I have the "Limitation" of 'CIRC. APCH. -VMC ONLY' on my 73 type. The SWA application question asks if you have an "Un-restricted" 737 type? I answered I did not, deciding to err on the side of caution. Would someone that got their type through USAir please comment if this "limitation" was a factor.
typhoonpilot said:Ask USAirways contract training about getting the limitation removed. A friend recently did it through them for a very reasonable cost.
That said, and being just a little bit pedantic here, limitation and restriction are not the same thing. I don't have any restrictions on my type rating, I do however, have a limitation.
Thanks Typhoonpilot,
I will do as you suggest. I had asked a buddy of mine from the training dept. at USAir (He's furloughed now). He wasn't sure how I could get the limitation removed. But now that I know that it has been done, its's just a matter of talking to right person.
I still haven't heard if SWA even does circling approaches?
GVE
