I haven't seen many Airtran pilots complain. Certainly not Ty or even Lear70, although Lear had the moderator title and then stopped that. I think they think it is interesting to watch. They will be flying with you someday, and this board gives a bit of insight into what they may deal with. What will happen after arbitration? I went through that. It was a shock for some at first, and then they got over it. It was done by an arbitrator, not by other pilots they would fly with. That is why most have gotten over it. Today each pilot group flies with each other, and it isn't bad at all.
But, there are a couple of ways to do it, and the USAir way has proven to be the bad way. They did it with the arbitration first, and then a joint contract. I think that is the way you are doing it, and that may lead to bad feelings if one side holds the award over the others' head (USAir) and doesn't agree to a joint contract. Hopefully you do not do that if you disagree with the ultimate award.
There you go, a civil discussion. You can agree or disagree, but those are the choices. An SLI without an arbitrator won't work, and never really has on a big scale. An outside opinion on what is fair is just that, fair.
Bye Bye---General Lee
You are incorrect. This is not like USAir or delta. There is no joint cba. Also how does that transition? That one I will just sit on since you haven't even thought to bring it up.
Point is, you have only your experience. I respect that as well as your opinion. This is however a very different process with very different companies and cultures. Heck it's even a different corporate transaction.
What was best for you may not be best for either pilot in this case.
Moreover you are to an obsessed position with the matter. It is what it is but let it be. Enjoy your life. Enjoy your friends and family. It's ok. We will be ok. The airtran guys will be fine. The Swa guys will be fine.
It's time to move on.
