Jedi_Cheese
Remove your shoes please!
- Apr 2, 2004
In my aviation law class, I feel that my prof made two mistakes (I think, if not it's my mistunderstanding). The major problem is that I am an undergrad and he is a local judge, so if it comes down to credibility on who to believe, I'm going to lose. So, I need some help finding a goverment publication (of some sort, can include court cases - actually perfered) that spells out the regulations on these two issues.
The first is that he said that you shouldn't physically give your pilot's certificate to the FAA inspector during a ramp check because it may be thought of as surrendering your certificate. I believe this claim to be false A quick search on these boards showed that I am in the right but I need proof of it somehow.
The second is that an ASRS form can't be used in an enforcement action against you and you get off the hook. I believe that an ASRS form's title can be used against you and that using the form only waives any action the FAA can take against you, you will still have it on your record.
