JAFI said:Well then, your mind is make up.
Good Luck
JAFI
Bad spellcheck on my part. What I ment to say was: Well then, your mind is MADE up. Good luck.
JAFI
Good Luck
JAFI
bobbysamd said:May I suggest that he/she and you read Practical Aviation Law by J. Scott Hamiliton. This is a well-known book that is used widely as a text in aviation law classes.
npowless said:It's been a while since I took Aviation Law, but is that not the book that states that if an FAA inspector takes your certificate it is a surrender of your certificate, and you should scream "bloody murder" on the ramp so he can't get away with taking it from you?
Like I said, it has been a while, so I am not sure if this was the book we used or not... but whatever book we did use, it did say that.
Nathan
CapnVegetto said:I know that's what ol' Bob Ripley used to say!!![]()
JAFI said:Some minor points...
Examiners do not have credentials (110A). Examiners are pilots or mechanics (not employed by the FAA) that are authorized ONLY to give examinations for certificates.
An FAA Inspector has a specialty (in no special order - pilot, mechanic, dispatcher, Avionics or Cabin Safety) and is an FAA employee who has a 110A for access to the cockpit and for identification.
jetdriven said:two kinds of Feds I have ran across, maintenance and airmen. Maintenance feds like to look over the airplane for smoking rivets, missing or inoperable items, and inspect the maintenance records. The airmen feds are interested in the qualifications of the airman, and their manner of aircraft operation, etc.
This is a little bit misleading. While an ASRS report won't stop enforcement procedings it will put an end to the process.A Squared said:2, if you are in an enforcement, don't bring out the ID strip and give it to the FAA. It won't stop the enforcement proceedings, and if they have sufficient evidence for a violation, you're going to get the violation, regardless of the NASA report. Save it until after you get the violation, then present it to have the penalty waived.
C425Driver said:In some cases ASRS can't help you - reckless operations or criminal activities are not protected under the ASRS program.C425Driver
