JudgeSmails218
- Mar 8, 2004
Well Ghetto....you can see quite clearly that the tow bar is still hooked up. If they were short staffed then they are supposed to wait for wing walkers. In Boston I do believe it is a requirement that there are 3 wing walkers because you have to push, turn and pull to a spot. JetBlue was parked at their gate.
Next, why yes I do know how to push aircraft back. In fact I worked the ramp at that exact concourse for delta while in college. We used to have to push back through a very tight spot in Boston. In fact the L1011 had 5 feet of wing tip clearance as you pushed turned and pulled it through. So I am quite comfortable in the process.
I do support my fellow union people. But we as flight crew get harassed and ignored quite often by ground crews. The problem here (I did accident investigating and violations for ALPA at a previous airline) is that THE FLIGHT CREW WILL NOW HAVE A INCIDENT OR ACCIDENT (depending on the amount of damage) FOR THE REST OF THEIR CAREER BECAUSE OF NO FAULT OF THEIR OWN.
Any other questions?
How can the flight crew have an incident on their record from something
like this? Control moves to the ramp during a push back. The pilots
can't see the wing tips in most cases.
