Southwest "exits" runway.....again.
msmb
Just saw tail end of report. I believe it was Newark. I think its funny how they say they exited the runway. The didn't run off the runway.
from SWA Facebook
STATEMENT ON FLIGHT 4695:
This morning, Flight #4695 leaving Islip for Tampa exited the taxiway during taxi from the gate. The aircraft had 129 Customers on board, and there were no reported injuries. The Customers deplaned the aircraft and were bussed back to the terminal where a replacement aircraft will take them to their original destination. Maintenance crews are working to move the aircraft and evaluate it for any damage.
My only point was that the way it was worded by southwest was pretty funny. It can and will happen to every airline. It just seems to happen with Southwest more than others.
Any aviation insurance actuary could give us the numbers on how often this will occur. It can and will happen to every airline. Hell, Air Force One put one in the tulips several years ago.
All the best to the SWA crew as they deal with the situation.
SWA
http://morichesdaily.com/2012/12/southwest-737-veers-taxiway-macarthur-airport/
Air Force One
http://articles.chicagotribune.com/1998-01-28/news/9801290008_1_plane-runway-andrews-air-force-base
Cannot believe........................................the Genitals hasn't chimed in yet.
She's over on the regional board this week, building his lead in postings and sharing his wisdom of the current state of the airline industry. Oh and further feeding her ego.
And once again, without actually knowing diddly-dick, a moron leads a piece and titles a thread about running off a "runway," to make it sound more ominous, like it's closer to a "plane crash," and not to mention attention-getting.
It was ISP, not EWR, and the plane apparently got off a taxiway in the winter weather.
But hey, MSMB, look at the bright side: you may not know crap about actual airline operations (like the fact there's a pretty significant difference between a runway and a taxiway), but you've shown yourself well-qualified to be an "airline expert" on the evening news. Good luck with that.
Bubba
You Southwest guys need to SLOW down
Seriously. I watched a SWA guy in Oakland almost enter a power slide turning from victor to tango over the summer. I was cleared to taxi out on bravo ahead of them and I didn't move because i thought they were going to lose it for sure at that speed. They made it but the items in the overhead bins shifted for sure.
Cheers,
Scott
Bubba
Easy there bubba. If you take a deep breath and go back and read my original post, I said "I believe" and that I only saw the tail end of the report. The reporter did say runway. I just got the EWR part wrong. The reporter got the location at the airport wrong. I guess if you end up in the grass, you would assume it was the runway.
I don't think "exiting the runway" is closer to describing a plane crash. Now if I had said that southwest flew off the runway at a high rate of speed, that would have been ominous! At the end of the day, you really don't need to get that defensive. It could happen to anybody.
Delta had a MD 88 do the same thing in CHS, it was raining, dark exiting the terminal ramp.
The nosewheel slid off about three feet into the mud near the taxiway edge.
The picture of the SWA at ISP shows all three gear in the mud.
Were they clearing the ramp or was it on takeoff?
Sure, it absolutely could and has happened to anyone. I'm sure whatever airline you work for as well. Care to say what that may be?
However, you were quick to jump on a bandwagon without any facts whatsoever. The only part of your post that indicated any uncertainty was the location; the rest of it you posted as if it were fact, even making fun of the reporter's term "exited the runway," as if that were a euphemism for something worse. Ditto your thread title, with the quotes indicating skepticism, and "again," as if it happens all the time to Southwest.
Bubba
Probably a colonel
Incredibly witty repartee, there Capt1900. Make that up yourself? Are you trying to give the General a run for his money as resident FI witmaster?
I'm a little confused, though. Are you calling ME a colonel, or the other guy? Was it intended to be an insult of some sort, or are you just expressing your general disdain for the military? For the record, I am not now, nor have I ever been a colonel.
Bubba
Bubba. You alright man? Merry Christmas brother
Btw- Colonels are great. Kernals suck
You guys need to slow down. You are only hurting yourselves at the end of the day by having this happen over and over and over again.
^ ^ ^ This. I am NOT a SWA basher, so don't play that angle.
You don't even know if speed was a factor. I saw a MD80 in SLC come off of 34R years ago. The guy went between two runway lights into 15 inches of snow. He did a nice slow 90 degree turn then planted it. The runway was closed for almost a day.
There's three sides to every story. The pilot's side, the FAA's side, and the truth. ;)
Seriously though, back in the day as a 727 CA we were entering the ramp up in Michigan after it had been snowing for 2 days and wasn't letting up. We were CRAWLING... and I do mean CRAWLING, went to slowly turn the tiller and... plane just keeps going right ahead towards other planes.
Let off the brakes, center the nosewheel, pull all 3 into reverse until we're almost at a stop, the dump the left engine back to normal idle and start turning the tiller again, using reverse thrust on the right side as drag. Is it approved? Nope. Did it work? Yup. Airplane wouldn't come to a stop without leaving #2 in reverse with a little thrust on it, then had the ground crew chock the brakes before shut down.
Sometimes it's just that slick and there ain't crap you can do about it. ISP sucks for snow removal anyway, used to fly Lears in and out of there every week.
That said, I watched a SWA CA enter B12 at BWI week before last going so d*mn fast even the marshaller started hopping out of the way. Thought he was going to hit the jet bridge but slammed on the brakes in time. Freaking idiot.
I'm sure it's a very small percentage of people that do it, I've had to make one or two of OUR CA's slow down before, and I'm sure this is just a slick taxiway issue. Crap happens.
Ohh! Look! A chance to trot out my long held grudge, hostility, or whatever against SWA for a little exercise.
Now, I could have taken the time to look at the evidence in this Islip incident, but I didn't want anything like facts to get in the way of that good, superior feeling that I get when I stand on my pitiful, small-man's version of the moral high-ground and repeat yet again the same old sweeping generalizations. (just dust off the good old "I saw the airspeed indicator come alive during taxi" and the "I saw a marshaller jump out of the way" and change the date-stamp to last week or last month and I'm the most relevant guy in the thread, which I really, really like to be).
Yes, if you'd taken the time to look at the reports of the scene at Islip you would know that: 1. it occurred during taxi out to runway 6, and 2. the Captain just didn't read the 10-9 very well or he'd have seen that taxiway S makes a right-hand bend before you can make the 90 degree left turn onto taxiway A.
Of course this requires some knowledge of Aviation, not X-Box games in Mom's basement (you know who you are).
If you work anywhere in aviation with a pilot group of more than 10 or 20 you're going to have at least one idiot. Acting like SWA has any more idiots per capita than any other airline is wishful thinking on your part.
Anyone care to chime in on that one?
Why? There's brakes on our side, too,,,
Everyone has their share of people who taxi a bit too fast in some situations. A well-timed "Are you trying out for Nascar or should we maybe slow down a bit?" tends to work wonders.
Some people just need a gentle reminder that there's two of us up there for many reasons. A backup for safe operations is one of those reasons.
Actually, since absolutely nobody got hurt (just like last time), I'd say that we're only giving guys like you fodder for SWA bashing. Hmmm.... "over and over and over again"... I suppose things never happen to other airlines. So what airline do YOU work for? The perfect one, I'd imagine.
Say, aren't you the guy who's normally drunk when you post?
Bubba
Fact: We fly ONE MILLION TWO HUNDRED segments/yr. Something is GOING to happen. Mud on tires SUX. Pissed off New York passengers SUX. The FAA SUX. After a tug job and getting sprayed off, it'll all be water under the bridge. Good thing the flying public has short memories.
An AirTran captain did the same thing a few years back at FLL between T5 and T6. It was early and dark, and he got fired. Of course the guy was talking on his cell phone at the time. The yellow line is your friend!
A man has gotta do what a man has gotta do... to catch his commute.
that's why it's good to very seldom taxi like you stole it.
Then you won't have to dial back anything when its slick out.
