Southwest Cockpit
citabriapilot
V Murdda...
Noticed on airliners.net that most of the 737NGs at other operators have a typical PFD with tape gauges, while the photos I saw from Southwest had a "six-pack" style setup with all the typical instruments, just in the six pack design and no tapes.
Is that how Southwest wants it, or is it just a preference that the flight crews can change back and forth? Or a difference in the avionics?
Just curious
Carriers opeating as a mixed fleet (Classic + NG) do this almost universally. CAL has the same configuration. Keeps the scan the same when you jump between generations on a daily basis. Flight crews can't change it. A pity, really. Operators like Air Berlin use the full functionality, and it's beautiful.
SWA pioneered the concept and requested round depictions when they ordered the NG's. There was initial resistence, but now there have been some studies that show that analog depictions (round dial with a needle) are much more intuitive than tapes. The eye, especially peripherally, can quickly detect a needle out of its normal position much easier and more quickly than decipher an indication on a tape.
Yah, und der AirTran makes mit all of der functionality, too . . . . including der go-faster automatikly and der stoppen-quickly mit der fus on der floorboards, too.
So whats up with no A/T, or VNAV, is this a standardization thing also? Again why not use the technology that is aviable?
Just asking,
I call bullsh1t on this one. Source?
Just asking,
I think it's called "Being a Luddite"
USAFftrplt said:
same reason that folks still buy Stick Shift cars..saves costs..not needed to get the job done
And because it's a lot more fun to drive a stick. I don't have much glass experience, but I enjoy flying round guages and don't really look forward to moving on to a plane with glass.
So did I detect someone saying that Southwest doesn't have autothrottles? I jumpseated on a -300 and the pilots set all the power settings by hand, but I thought the throttles had the words A/T Disconnect next to a button stamped on them.
Maybe for an engine gauge. Not for airspeed and altitude. We aren't gonna see round dials on the 787, for example, and there's a reason why.
I'm not a SWA pilot but I know many and have ridden up front many times. yes they have autothrottles but they are disconnected. So they can't use them and the power must be set manual. Also the v-nav button is blanked out so they can't use it either, but the box still can be programed to give them a v-nav descent/crossing restrictions but it has to be flown with vertical speed and manual power adjustments.
Wait, if you ever get into a glass enviorment, you will never want to go back to round dial.
By glass I mean the full thing, not the half and half like some older 73's or most 75's
It's called "half-a&&ed" glass
