mattpilot
Finally! Graphical TFRs!!
- Sep 30, 2003
cougar6903 said:Matt, where are you doing your training? I am also interested in getting an add-on in a 47.
In Tulsa OK - $190/hr
still interested?
GVFlyer said:In most sophisticated helicopters maintaining around 60 knots in autorotation will provide directional control in the event of a tail rotor failure. In the SH/UH-60 the tailrotor is even canted so that tailrotor thrust offsets it's weight should you lose the tailrotor entirely. In the Bell 47/ OH 13 Sioux, the helicopter just spins until impact with a tail rotor failure.
GV
mattpilot said:Why wouldn't an auto-rotation in a tailrotor failure situation save you?
Fox6 said:In most everything that I have flown, which isn't much granted, this is the procedure outlined in the Flight manual for tail rotor failures. It would be interesting to hear from someone who has actually experience a t/r failure in a 47 or any other helicopter for that matter. My co-worker has a lot of time and two engine failures in the 47. Both had successful auto's fortunately.. He worked cattle with them back in the eighties.
f6
mattpilot said:In Tulsa OK - $190/hr
still interested?![]()
cougar6903 said:Fox, Is that the Brantly B2 you mention in your profile? If so can you answer some questions about it?
Fox6 said:You don't hear a lot of people training in those for some reason, but they might be great, who knows.
Fox6 said:Well, I wasn't going to say it....... hopefully there is not too many offended B2 drivers out there., but it is ugly.
Fox6 said:If your "in autorotation", (the way I understand it) then there should be no power therefore no torque applied to the transmission, therefore no spinning. If anything, you would have transmission drag which will actually tend to turn the helicopter the opposite direction as torque. Looking at your flight time and aircraft flown, you may know something I don't. Did you mean that 60 knots in POWERED flight will mainain some semblence of directional control due to the vertical stabilizer (asymmetric in the Astar) taking the load off the tail rotor.
I've never had one myself. Had a friend lose a tail rotor in an OH-6 while in a OGE hover. He said that it was extremely fast and was on the ground before he knew it. He instinctively got the power out though as fast as he could and hit upright before rolling over.
helimech said:First of all, back to Matt's original question.....I've flown both the R22 and Bell 47 and have quite a bit of time in them. They both have their strong points. The Bell 47: Extremely stabil aircraft!! Very forgiving, even with loss of tail rotor thrust (IF!!!!) you have metal blades!!! If not and you have the wood blades, well then you have to be very cautious your last 75 feet down with your airspeed, but it is definately do able, I used to do it all of the time (on purpose and not on purpose).
helimech said:The R22 on the other hand... you have to watch everything a little closer and have to be right on it when you lose anything... engine, runaway governor or tail rotor if at low airspeeds. The only thing i can suggest Matt is to go up with an EXPERIENCED instructor on the R22 and he/she will show you exactly what the aircraft can and can't do... for the commercial checkride in any of the Robby's you have to demonstrate everything!!! Low G pushovers, loss of T/R, engine, electrical system, everything!! They are both fun aircraft to fly. As for the 300, I haven't had very good luck with those! All the ones I ever fly are because they were rolled over and have just come out of maintenance and they always suck after that!!! But try as many as you can!! Just to get your license out of the way, finish up with the Bell and then transition over to the Robinson. One of my customers told me the other day, that they would rather hire somebody with 200 hours in an R22 then somebody who has a 1000hrs flying any type of turbine, because you definately are on your toes when you fly an R22....
GVFlyer said:How would you simulate (on purpose) a loss-of-thrust tailrotor failure? Put in full right pedal and hope for the best? And maybe it's just me, but I don't think I'd be flying a helicopter that had me doing tail rotor failure emergency procedures, "all of the time (...not on purpose)."
Our company had an instructor that would simulate a tailrotor failure in a hover in a OH-6. Basically by releasing pedal pressure on the left pedal. The recovery was to initiate a hovering auto by rolling the throttle off. He was the only instructor out of five that would do this though. His exprience level was high enough though to get away with it. This is only possible with a collective mounted throttle however. In the BA-B2 Astar, the "fuel flow control" is on the floor and the procedure for tail rotor failure in a hover is to, and I'm paraphrasing this, maintain level and lower the collective until you contact the ground. Hopefully the rate of turn won't be too extreme with that big vertical stablizer on back, but I'll bet it 's still pretty ugly.
