Skydive airplane accident
Traderd said:
Want even more confusion? The article says:
"Witnesses said they saw the plane sputter shortly after takeoff around 3:15 p.m. and crash onto the runway."
If you are curious how a turbine can "sputter", I am even more curious how one can "see" an aircraft "sputter".
Simple, he saw flames of the re-light comming out of the exhaust stack in intermittant belches of flame.
Next time you are in your buddies TBM or Pilatus PC 12, get him discombobulated during the after landing checklist. When he reaches up to grab the fuel condition lever, distract him enough to pull it into "idle cut-off". When he freaks out and jambs it back up into low or high idle, watch for the flame thrower to come out of the exhaust stack and tell me that don't look like one big sputter.
Riiiiight. Maybe the "witness" was just another toothless, mouth-breathing, inbread with a 40oz and a wifebeater looking for his 15 minutes...
I've been involved with the media subsequent to a couple of unfortunate aircraft accidents and make no mistake, reporters will turn over every rock until they find someone who "saw" the plane "sputter" "catch on fire" or get hit my lightning or a missile or otherwise support whatever sensational BS angle that will get the most viewers to tune in at 10.
FlyFlyFly said:
Sorry to get technical, but someone else started it...
Not all PT-6 engines have a single stage reaction turbine. Many of the higher powered models have two stage hot sections, which may just, in the right conditions, make them more susceptible to sputtering.
Bonus points if my friend can fill me in on the purpose of the original turbine engine the PT-6 is based on and what consequences sputtering may have caused in this application.
Point 1, you're right about the multiple stages; i still hate the semantics of sputtering....
Point 2, I believe it was inresponse to the world wars that a helicopter engine was to be created which was not a recip engine.
Maybe he was a Democrat at that. Thank you for calling.
I'm a little confused by your kitchen references.
First, while there are hundreds upon hundreds of types of bread, I've never heard of "inbread." I read that there are over 300 types of bread in Germany alone. Of course, we all know that there are numerous types of French bread. There are leavened breads, and unleavened flat breads. Even here in the culinary-deprived South, we know of sourdough bread, white bread, wheat bread, rye bread... we know of dinner rolls, sweet rolls, cinnamon rolls, and bagels... occassionally we'll even have a pita with a Greek or Mexican specialty. But I've never heard of inbread.
Might it be a contemporary blending of the word bread and the use of "in" that means popular or currently chic? Last week rye bread was inbread, but this week raisin bread is inbread? (And rye bread is now outbread?)
Of course, I've never heard of any kind of bread being literally toothless (another colloquial reference, no doubt) and I've never heard of bread "mouth-breathing." Some breads are bland, and bland can sometimes be described as "having no bite," so I'm guessing that "toothless" might relate to the lack of interesting flavor. And many breads are best stored where air can circulate around it, so the breathing reference might have some relationship to that, but the mouth part of that method suggests less than sanitary conditions, at least in my mind.
Secondly, I've never heard of something called a "wifebeater" that might compose or be possessed by a bread. You say the inbread has a 40oz, which presumably is a reference to a low-quality beer, so we're given a peek at the ingredients list of this elusive inbread. I'm thinking of a sour-dough type bread with a long fermentation phase, but that's just a guess. But where does this so-called wifebeater come in? Is it anything like an eggbeater, perhaps a utensil used to mix or rotate the ingredients at some point in the process? Is it a tool designed for the diminutive frame that has hence been labeled, in that loving, sexist tradition, after the fairer of the matrimonial pair? Can we see a picture of this utensil on a website?
I have no idea how any bread could witness an airplane incident or look for 15 minutes, but perhaps that will become evident when we learn more about this special bread. I, for one, am anxious to discover even more bread talents.
Doug Parker said:
I wonder if he'll get a Violation for being over-gross and out of CG
Hey Doug- I didn't know that you worked for the NTSB? That's a big one to "ASSUME" with no valid info! :smash:
cforst513 said:
i have noticed the same thing. in fact, when i was working on my private, i went from DAB to MLB for a solo X-C on V-3 and on the way back up 4 parachutes popped out of the clouds a few miles ahead of me. i immediately turned about 90 degrees left and went westbound, paying close attention to dunn. it too is an uncontrolled airport. dangerous. i was talking to ATC with VFR flight following, and i didn't hear a peep. i told ATC and also then monitored the CTAF freq for dunn to make sure no other jumpers were gonna show up unexpectedly 2 miles in front of me.
You sure that they came THROUGH clouds, and not between clouds? Also, what ATC facility were you talking to? The pilots report(and are required to do so) jumpers away and whatever call prior to that the specific ATC facility wants(usually 3 minutes to jumpers away). At Dunn, that report is usually made to Jax center... If you didn't get a call from ATC warning you of skydiving activities....whose fault is that? The jumpers? The pilots? Yours? ATC's?
Why are you flying directly over an airport with a very active skydiving operation? I can't tell you how many times I was in the door at 15,000' over Dunn spotting the load and had to call a go around because some idiot in a Cessna was flying directly over the DZ, totally oblivious to the fact that there is an active DZ there.
Keep in mind that from the time a group exits until they are on the ground can be up to about 7 minutes for sport jumpers, and 10+ minutes for tandems. Canopies are deployed between 2,000' and 6,000', depending on type of jump and experience level. If you're cruising along at 2500', moving along at 2 miles per minute....you could be 10 miles away when they exit, and still encounter tandem parachutes at your altitude when you cross the airport.
Learn to avoid airports that have active skydiving operations unless you intend to land there. You only have to turn a few degrees to go around them. Jumpers will exit over or upwind of the airport(winds aloft, not surface winds), generally about a mile or less. The stronger the winds, the further upwind they will exit.
Exactly.
FracCapt,
He said he was flying on V3. I don't think there's supposed to be too many jump ops on the airway.
wrxpilot said:
FracCapt,
Assumptions can get you killed.
FracCapt said:
Why are you flying directly over an airport with a very active skydiving operation? I can't tell you how many times I was in the door at 15,000' over Dunn spotting the load and had to call a go around because some idiot in a Cessna was flying directly over the DZ...
That's a helluva place for a Cessna to be; over an airport. I had some idiot skydivers falling around me while doing the DME arc at Daytona, had to abort.
I was over Dunn, on V3, on an IFR flight plan, punching in and out of clouds (I'd say SCT) and had some jumpers to my east. Not extremely close, but I noticed em...
Pilot To Be Charged With Manslaughter After Skydiver Hit In Midair
POSTED: 4:28 pm EDT October 5, 2005
UPDATED: 6:08 pm EDT October 5, 2005
The Volusia County state attorney's office plans to charge a pilot with manslaughter for the death of a skydiver in April, according to a Local 6 News report.
Albert "Gus" Wing III of Longwood was finishing his free fall when the plane he jumped from hit him. The skydiver's legs were severed at the knees and he died shortly after landing. The pilot, William Buckman, will be charged with manslaughter and wreckless operation of an aircraft, Local 6 News has learned. Deland is about 40 miles north of Orlando.
http://www.local6.com/news/5062103/detail.html
FN FAL Just because you saw a plane appear to "sputter" in the movie "Fandango" it doesn't mean that all planes have to "sputter" exactly the same way.[/QUOTE said:
That was a popular movie around the DZ on rainy days. Fandango and beer.
Anyone have more details on this accident?
Hey V-stall + FN FAL
Go do the Wt + Bal on a Porter with 10 pax - 10 to 1 says you're gonna be aft loaded and overweight. (not to mention pretty fxxking cramped)
I did do the math Mr. NTSB man, and the conclusion is you have no clue what you are talking about. BTW>>> do you know what "ASSUME" stands for?
Doug Parker said:
Hey Fricknut,
How much porter time do you have?
I rest on your face...........
And how much time do you have in an H4 Porter? If you're calling people out on experience you might want to provide some of your own. Help us understand you.
Another problem here could be that the trim was left in landing position. Isn't the first time a jump plane crashed due to this. If this is the cause it wouldn't be the last either. Last one I know of was a C-206 in Jacksonville. Plane breaks ground and then pitches up hard, stalls, rolls left or right, hammers in. I'm just glad no one was killed in this.
Doug Parker said:
Full nose up trim is Not unmanageable in an H4.
And how much porter time do you have DiverDriver.
I asked you first.
Ahhh, Mr Hicks, I think that we have a major malfunction here?.....pull the ripcord, pull the handle on your tum tum....
A whole days laundry shot to he!!.....
"Hit your reserve! Hit your reserve!"
<thump...thump...thump>
Pull the handle!
GO-ON!
NO-GO!
Wow, man. Looks like he missed the mattress. Bummer.
But wait, man! I gotta tell you about my dream! I wanna hang glide off Mt. Everest! But that's not the best part. Naked, man! Hey, Mr. Hicks, you don't look so good!
Yea...it's a classic! Those guys were so young when that was filmed.
Hey Doug, I'm not saying the crash can't be wt and balance related...I do 3 wt balances a day on a single engine turboprop and the people that load my plane know that I am pro-active when it comes to how and where they put the freight in the aircraft.
All I was saying was that if it is wt and balance related, we'll have to weight until the authorites way in with their findings.
As far as speculating about what the eye witness said, that's fair game...it was printed in the papers.
Porter a cramped ride? Yea, I sat on the rear seat with three pepole back when I was half as fat as I am now. I think we had 11 in that thing.
I've seldom been aboard a jump aircraft on the ride to altitude when it wasn't cramped. Have I ever been aboard one that isn't well within both weight and balance limitations?
Never knowingly.
Yea...healluva place for a Cessna to be....over an airport they have no intention of landing at, flying over at an altitude that could interfere with the flow of traffic there, and not even monitoring CTAF....all this over an airport with a very active skydiving operation, which is CHARTED. Do you train your students how to read charts? If so, they should know which airports have skydiving ops at them.
Something funny I've noticed....most of the comments such as yours are always made by high time wonders such as yourself. Maybe once you've been around the patch a few times you'll start to think differently and realize you are not the only person in the sky.....then again, maybe you won't.
