B6Driver said:"Why dont we compare W2's instead. Up to the challenge?" Pea brain.......
As I said B4, run along son.
RP 04 said:So did the FO push the rudder pedals, or not?
ils2minimums said:Due to the filter on the DFDR, we will never know. Did the pedals move as a result of the rudder movement, or FO inputs? Unfortunately, it'll take another similar accident before the answer will get a closer look from the government.
ils2minimums said:A note about the NTSB animations link in a post above. Those animations are based on a DFDR whose data was deemed ineffectual until it was reconstructed by two teams from, of all places, Airbus.
- Aviation TodayAccording to the NTSB, N14053’s maintenance log revealed that during a preflight check on the morning of the accident, "the yaw damper and a pitch trim control would not engage ... The computer controlling these functions was reset."
igneousy2 said:This would not be the first time the frenchies have been involved in a cover up.
Read:
http://www.amazon.com/Unheeded-Warning-Inside-American-Flight/dp/0070219516
Unheeded Warning documents the investigation of AE 4184 in Roslawn, Indiana. One part of the book claims that the State Department reversed an FAA grounding of the ATR. Yes...the State Department. Read this and you will never take an ATR into known icing again.
Later,
