B6Driver said:"Why dont we compare W2's instead. Up to the challenge?" Pea brain.......
As I said B4, run along son.
RP 04 said:So did the FO push the rudder pedals, or not?
ils2minimums said:Due to the filter on the DFDR, we will never know. Did the pedals move as a result of the rudder movement, or FO inputs? Unfortunately, it'll take another similar accident before the answer will get a closer look from the government.
ils2minimums said:A note about the NTSB animations link in a post above. Those animations are based on a DFDR whose data was deemed ineffectual until it was reconstructed by two teams from, of all places, Airbus.
- Aviation TodayAccording to the NTSB, N14053’s maintenance log revealed that during a preflight check on the morning of the accident, "the yaw damper and a pitch trim control would not engage ... The computer controlling these functions was reset."
igneousy2 said:This would not be the first time the frenchies have been involved in a cover up.
Read:
http://www.amazon.com/Unheeded-Warning-Inside-American-Flight/dp/0070219516
Unheeded Warning documents the investigation of AE 4184 in Roslawn, Indiana. One part of the book claims that the State Department reversed an FAA grounding of the ATR. Yes...the State Department. Read this and you will never take an ATR into known icing again.
Later,
Huck said:I cannot believe that more was not made of this:
- Aviation Today
Not that I'm a conspiracy theorist here, but guess what Egypt Air, AA 587 and the Alaska MD-80 with the bad jackscrew all have in common? They all had trouble with autopilot and/or yaw damper systems either not engaging or failing self-test immediately prior to their accidents.....
Dangerkitty said:I guess holding for about 45 minutes in heavy icing with the flaps down had nothing to do with it.
igneousy2 said:Yes and no.
Yes the plane would not have crashed had they not been in heavy icing with the flaps down for 45 minutes.
No...it should not have crashed under these circumstances. The main cause of the crash was an uncommanded roll caused by the Ailerons moving because of the way the ice tended to acrete on the ATR's wing. It was not the typical load the airplane with ice and stall scenario.
Since you probably aren't going to bother to read the book as you have flown the airplane in question but still haven't bothered to gain more than a laymans understanding of what happened I suggest you A. read the book or if you don't like conspiracy theories...B. read the NTSB report.
http://www.airdisaster.com/reports/ntsb/AAR96-01.pdf
The National Transportation Safety Board determines that the probable causes of this accident were the loss of control, attributed to a sudden and unexpected aileron hinge moment reversal that occurred after a ridge of ice accreted beyond the deice boots because: 1) ATR failed to completely disclose to operators, and incorporate in the ATR 72 airplane flight manual, flightcrew operating manual and flightcrew training programs, adequate information concerning previously known effects of freezing precipitation on the stability and control characteristics, autopilot and related operational procedures when the ATR 72 was operated in such conditions; 2) the French Directorate General for Civil Aviation’s inadequate oversight of the ATR 42 and 72, and its failure to take the necessary corrective action to ensure continued airworthiness in icing conditions; and 3) the French Directorate General for Civil Aviation's failure to provide the Federal Aviation Administration with timely airworthiness information developed from previous ATR incidents and accidents in icing conditions, as specified under
the Bilateral Airworthiness Agreement and Annex 8 of the International Civil
Aviation Organization.
One of the main points was that the ATR had boots that did not extend far enough back to prevent ice from accumulating behind the boots especially in the area immediatelly forward of the Ailerons. A ridge of ice would form that disrupted the airflow around the Ailerons in such a way that it would cause an uncommanded deflection of the control surface.
It was later determined that the boots needed to extend X% (I forget the number) of the wing chord to prevent the undesireable ice accretion. The ATR boots at the time of the accident actually extended back far less than the X% that was calculated. The ATR boots were redesigned by ATR to extend back further...closer to X after the accident, but for some reason, going back any further would cause the entire wing to need to be redesigned. So the redesigned boots extended farther back than the accident aircraft, however, in the FAA's view it was still not back far enough.
The FAA was not going to accept ATR's redesign but the State Department used it's much higher political clout to force the FAA to cave. This was during a time period where the 737 european certification was being threatened because of the uncommanded roll problems that the 737 was having. Basically, it was "you revoke the airworthiness certificate of the ATR we'll revoke the airworthiness of the 737" kind of situation.
Anyway, I read the book a long time ago, that's the jist of it as I remember it.
I wonder why AE never lets any of their ATR's any further north than Florida?
Later
Amish RakeFight said:Maybe I'm confusing this with another accident, but didn't AA587 (really the particular plane in service at the time) have some issues with improper tail damage repairs which may have caused a weakening of the rudder. Am I thinking of JAL 747 empennage or was this a possible factor in the Airbus accident as well?
Dangerkitty said:Actually I tried to get the book a few years ago but at the time it was out of print.
I understand and don't dispute what you are saying. However, de-ice boots are only there to buy the crew some time and give them some options. They should not be used to stay in icing conditions that are moderate at best.
Furthermore, while the FO was holding in icing the Captain was in the back socializing with the FA's. Not really the best use of CRM in my opinion.
I did not read the entire thread, so please excuse me if this has been mentioned:
There is a video of AA587 EXPLODING in mid-air. If the tail ripped off, I don't think the aircraft would have exploded IMHO.
