PhatAJ2008
- Jun 24, 2005
Landing...not takeoff...Anybody ever consider that many times a very short strip might also be soft? This is where PTS meets reality and learning at the rote level might leave you a bit short. Short answer, soft field technique, but keep it rolling around the corner. Lift off into ground effect at minimum airspeed to eliminate the rolling drag, and accelerate to Vx to clear obstacles at the end of the short runway that is also soft. Technique also works well on a firm grass strip that is in need of mowing. Amazing how much drag long grass can add!
Well from your standard, run of the mill short field landing perspective, you could dig your way into the ground by using max braking on a soft field.
It would seem to me that just sticking to the normal soft field technique would be fine for a short soft-field, as the extra friction of the ground should do the trick in slowing the airplane...
It's unfortunate that a combo short/soft isn't a choice on the PTS. That doesn't stop us as instructors from teaching some combination techniques, but there are many different ways of extrapolating the two, and the extrapolation would be dependent on the unique conditions of the shortness and softness of the landing strip being considered.Heard the DE has students so a short and soft field landing at the same time. How would this be performed? Use breaks? Flaps?
You can hit the brakes pretty hard and not dig in on a dry grass field from what I've seen in the GA stuff I flew.
