PhatAJ2008
- Jun 24, 2005
Landing...not takeoff...Anybody ever consider that many times a very short strip might also be soft? This is where PTS meets reality and learning at the rote level might leave you a bit short. Short answer, soft field technique, but keep it rolling around the corner. Lift off into ground effect at minimum airspeed to eliminate the rolling drag, and accelerate to Vx to clear obstacles at the end of the short runway that is also soft. Technique also works well on a firm grass strip that is in need of mowing. Amazing how much drag long grass can add!
Well from your standard, run of the mill short field landing perspective, you could dig your way into the ground by using max braking on a soft field.
It would seem to me that just sticking to the normal soft field technique would be fine for a short soft-field, as the extra friction of the ground should do the trick in slowing the airplane...
It's unfortunate that a combo short/soft isn't a choice on the PTS. That doesn't stop us as instructors from teaching some combination techniques, but there are many different ways of extrapolating the two, and the extrapolation would be dependent on the unique conditions of the shortness and softness of the landing strip being considered.Heard the DE has students so a short and soft field landing at the same time. How would this be performed? Use breaks? Flaps?
You can hit the brakes pretty hard and not dig in on a dry grass field from what I've seen in the GA stuff I flew.
They are always handled separately regarding Private training.
That's sort of the point that I think a couple of folks were making. The PTS task is a step-by-step, by-rote, snapshot of one discrete skill set that, in the real world, is part of a bigger picture. In that bigger picture, what you are supposedly learning from this, and the other maneuvers, is a set of skills that give you the ability to control the aircraft - ultimately you have to apply and correlate (to use the buzzwords) so that you use the skills you have to meet the situation you are in.Well from your standard, run of the mill short field landing perspective, you could dig your way into the ground by using max braking on a soft field.
There was a story a few years back about a pilot who took off from an airport and had an engine problem as he flew over a downtown area and did an excellent short field landing on the roof of, as I recall, a supermarket.Granted, nobody I knew had to land a cub on a roof,
The pilot stated that he changed the engine oil and cleaned the oil screen 1 week before the accident; however, he did not operate the engine with the cowling removed after the oil change to check for oil leaks. He is not an Airframe or Powerplant mechanic but is authorized by 14 CFR Part 43 to perform preventative maintenance to his airplane which includes lubrication and cleaning and replacing oil strainers or filter elements.
C. TASK: SOFT-FIELD TAKEOFF AND CLIMB (ASEL)
REFERENCES: FAA-H-8083-3; POH/AFM.
Objective. To determine that the applicant:
1. Exhibits knowledge of the elements related to a soft-field takeoff and
climb.
2. Positions the flight controls for existing wind conditions and to
maximize lift as quickly as possible.
3. Clears the area; taxies onto the takeoff surface at a speed consistent
with safety without stopping while advancing the throttle smoothly to
takeoff power.
4. Establishes and maintains a pitch attitude that will transfer the weight
of the airplane from the wheels to the wings as rapidly as possible.
5. Lifts off at the lowest possible airspeed and remains in ground effect
while accelerating to VX or VY, as appropriate.
6. Establishes a pitch attitude for VX or VY, as appropriate, and
maintains selected airspeed +10/-5 knots, during the climb.
7. Retracts the landing gear, if appropriate, and flaps after clear of any
obstacles or as recommended by the manufacturer.
8. Maintains takeoff power and VX or VY +10/-5 knots to a safe
maneuvering altitude.
9. Maintains directional control and proper wind-drift correction
throughout the takeoff and climb.
10. Completes the appropriate checklist.
