CatYaaak said:
Dude, you've been ranting and raving about how (in your opinion) stupid it is a Gulfstream has all that "expensive" equipment because you think it causes it to burn more gas and serves no purpose other than to boost a pilot's ego. Now here, not only do you say a Legacy has all those things!....but "hey anyone can buy it" too!
Make up your mind. Or is the problem you don't even know what a Gulfstream has in the first place? How can you know what it has when you admit you don't even know what standard equipment is on your own?
(now I'm sure....either a demo pilot at his first civi job, or an ex-regional guy at his first corp job... or a kid with a flight sim.).
You are clearly not very skilled at discussions of substance because you haven't been able to follow the course of this one too well.
For one thing, it is not my job to know what is standard equipment on the Legacy. I know what is on the airplane when I fly it and how it works. Knowing how it came to be there or what costs extra is the job for the dealer and the buyer, not the pilot.
You guys claim that the Gulfstream has four million pieces of equipment the EMB doesn't have. The reality is, the EMB has most of it and the things it lacks are not that important--they can be had if one wants with the exception of EVS (another gee whiz gadget that is only going to be used in the rarest of circumstances and probably isn't worth the expense)--for the bulk of the missions both airplanes fly.
Yeah, your airplane has fifteen redundant systems and can land on the deck of a carrier. Woopie. All that does is burn gas.
All airplanes are compromises. The EMB is a compromise in some areas, the Gulfstream is a compromise in others. No single airplane can do it all, and no airplane can do exactly what another can do. But the envelope overlaps enough for the overwhelming majority of cases to make the EMB a competitor to the Gulfstream. Call it what you want. You give the impression that G-String drivers are pious because yours is bigger, or a little faster, or can go a little farther. Immature if you ask me...
As I said, all airplanes are a compromise. Would an F-16 be the performer it is if it were fitted for carrier ops? Of course not! Would it be stronger? Sure. Over-engineering only goes so far however, and it does so at a price. Would the F/A-18 have better performance if built to USAF specs instead of USN requirements? You bet. But both are effective in similar roles. Each has its advantages and disadvantages, but both can do the job very well.
As for all this talk about the EMB being slow... If 0.90 Mach cruise speeds were the most efficient way to fly you can bet everyone would be doing it. But it isn't, and we don't. And anyone who has flown an EMB knows it will run right through the redline in cruise without a problem. That limitation is largely artificial.
The EMB is a good piece of equipment, with safety, comfort, redundancy, and efficiency all rolled into one package. And it is AFFORDABLE! I'm not so sure the terms efficient or affordable work in describing the Gulfstream.
(I love how people hurl insults when they start losing an argument.)
