Settle the Bet
jt8d is considered a jurboJET. The fan does not produce any appreciable thrust (5%?) compared to a turbofan. With the BR715 EPR is the primary control for the fadec, N1 is the reversion when sans computer.
Hmm... I don't think I've ever seen it called anything but a low bypass turbofan...
can you provide some sources?
How 'bout the JT9D Pratt & Whitney dual-spool \ axial flow \ high bypass Turbofan?
Fan produces 75% of the 52,000 lbs of thrust with a 5 to 1 bypass ratio.
...at least that's what somebody told me ;)
That's fine for a JT9D but we're talking about JT8D's :p
By who? You?
The JT8D is a turbofan. The 1.7-to-1 ratio Torqued mentioned is about right.
Now if it had no fan at all, then you could consider it a jurbojet.
(You have actually flown the '9...right?)
OK, this is a neat discussion, let me try my question again:
Are there any turboFAN (I did say FAN and not JET) engines out there where the primary measure of power is EPR, other than the CF700?
I conclude that the JT8 is arguably a turbofan, so it would qualify, therefore do you set power on it primarily by EPR? I assume the JT8 is that ultra low bypass affair of a stovepipe slung under the wings of 737-100 & 200s.
It also appears that the BR715 has a FADEC that uses EPR to set power, so I would assume the BR710s on a GV would have the same.
Any others?
Doh!
Disregard, I was coming in broken and stupid!
Due to the late hour and several coors lights, my post is factually innaccurate regarding turbojet. I've been off of the 9 for a few years, and am simply too lazy to look it up.
