I'm dealing with a critical application. If these fasteners fail, the results could potentially be fatal. I need maximum security. I've been torquing 1/2" grade-8 bolts to 135ft/lbs. Tonight, one of the bolts snapped in half while torquing. This made me rethink all the other bolts that I've been torquing to this spec. First, shouldn't a 1/2" grade-8 bolt withstand far more than 135ft/lbs??? If not, I need a general torque spec that will ensure proper bolt tension. Remember, if these bolts fail or come loose, the results will not be pretty.
Yes, I know that SAE bolts are not used on aircraft, but this isn't an aircraft application. I was however, hoping someone might know....
