I feel safer knowing that Line guys are the FAA'a "expert witness".In the case above the FAA has used 'expert witness' testimony from ground observers (tower, line guys, etc) to build a case against pilots who have done that
What case? The I heard from this guy who heard from this guy case? No references to reality AutoBus, just more useless hearsay...... With an attitude like that why go flying at all. Stay home, watch the weather channel, take shelter immediately! You might as well never go outside... If you know the rules, there is no reason to be afraid of what might happen..... Runway environment? YUP Stabilized approach? YUP, LAND. Do you think someone is going to be mad at you for making it in... "Well, that was such a low approach they never should have made it... I'm an expert, so I'm calling the FAA!" Whatever.....In the case above the FAA has used 'expert witness' testimony from ground observers (tower, line guys, etc) to build a case against pilots who have done that (part 91,121 or 135)
Not trying to be a dick, or get to far off topic but when I read this about going missed anytime I figured maybe a clarification was in order.WSurf said:But then again you can go missed at anytime in a approach!!
Things that make you go hmmmmmmm!
Flooder305 said:What case? The I heard from this guy who heard from this guy case? No references to reality AutoBus, just more useless hearsay...... With an attitude like that why go flying at all. Stay home, watch the weather channel, take shelter immediately! You might as well never go outside... If you know the rules, there is no reason to be afraid of what might happen..... Runway environment? YUP Stabilized approach? YUP, LAND. Do you think someone is going to be mad at you for making it in... "Well, that was such a low approach they never should have made it... I'm an expert, so I'm calling the FAA!" Whatever.....
FAA Legal Interpretation
March 10, 1986
Dear Mr. Johnson:
This is in response to your letter of February 6 requesting an interpretation
of Federal Aviation Regulation (FAR) Part 91, Section 91.116.
Specifically, you request clarification of the term "flight visibility" in
connection with the requirement in FAR 91.116(c) that an aircraft not be
operated below a published decision height or minimum descent altitude if the
flight visibility is less than the visibility prescribed in the standard
instrument approach procedure being used. The question arises as to whether
descent below the DH or MDA can be made when the runway visual range (RVR) is
reported at less than the published minimum RVR for the approach but the
flight visibility is greater than that minimum.
The flight visibility is controlling. If the flight visibility exceeds the
published minimum for the approach, then the pilot may proceed as long as the
other requirements of paragraph 91.116(c) are met regardless of the reported
RVR. The National Transportation Safety Board (NTSB) has upheld this
interpretation in several enforcement cases. However, the pilot's judgment
of flight visibility is not necessarily conclusive if there is a question as
to the actual flight visibility conditions at the time of the approach.
Reported visibility and other evidence of record may be considered by the
Federal Aviation Administration and the NTSB in determining the actual flight
visibility.
GINCHBLASTER said:So basically its your call. If you think you have the required flight vis and land, all is good. Unless the FAA/NTSB think that you are going too far, then they'll call you out on it.
