Need help from experienced long term aviators that have been taking Captain check rides for many years in 121 jet service.
Missed Approach Memphis TENN ILS 36L Index 11-6 16Jan04
I am conducting a Missed on 36L traffic on runway 1800 RVR
Go Around Go Around Thrust Positive Rate Gear Up
Speed Mode Bug V2 Right engine Fails, Right Engine Catches Fire
@ 400agl Heading Mode 1/2 Bank White Needles (FMS CDI) Auto Tune
@ 600agl Autopilot On oops No Auto Pilot, Whats the problem.
Non flying Pilot "Right Engine Fire and Fail
Flying Pilot "Do the memory items for Engine Fire
@ 1000 agl (1300 MSL) Flying Pilot calls "ALT Mode" NFP selects Alt Mode and continues Memory items for Engine Fire
@ v2 plus 20 "Flaps UP" NFP then continue memory items
@ VT " FP calls "Select Speed Mode Deselect half bank Set Max Continuos Thrust, I have the radios Complete the QRH for Engine Fire and follow that with the QRH for Auto Pilot Failure.
"Mem Tower Call sign so and so declareing a emergency with a engine fire indication request rwy heading climbout. Mem Tower says No. Call sign so and so executing the published missed. Flying Pilot tells NFP "Give me a left heading to intercept the 323 radial of Memphis VOR select my course indicator to 323 outbound and select freq 117.5 to active and select NAV Mode and go green needles on your side (Raw Data cdi on NFP side) Continue the QRH."
Did this pilot just bust.
Missed Approach reads
"Climb to 1000' then climbing right turn to 5000' outbound via the MEM VOR R-323 to MREON INT/D18.0 and hold.
The above I just did in the sim.
I wanted to tun out at 700 agl which is 1000' MSL for ILS 36L in Memphis with a TDZE of 321'
For our profile this would be right after selecting the auto pilot on at 600 agl.
The instructor said the Missed Approach procedure is only for if the radios are out.
He said the "Climb to 1000' MSL then climbing LEFT turn is the minimum altitude to turn.
In the scenario above I would have turned at or above 1300 MSL which is just after selecting a climb on the Flight Director at VT speed aprox 170 kts.
1300 MSL is 1000 AGL which is our companies acceleration altitude.
I have been sitting here lookinga all over the regs the internet and the AIM to fin out if what the instructor said is correct that 1000 MSL is the minimum only for the turn and that I can turn a little later after the priority of taking care of the engine out profile.
Please help before my check ride.
Don't want to turn out late if its not legal.
This was the worst the instructor could find for me.
Right engine Failure
Right engine Fire
Autopilot Inop
FMS Inop
Thanks Really Apreciate the help
Right engine Fire
Autopilot Inop
FMS Inop
