Super 80
Rube Goldberg device
- Oct 7, 2003
Last chance to help you conceptualize this.GogglesPisano said:Not speed. Time. In other words, how much time did that 75 mile journey by the balloon take? Nowhere in the clue does it state that the second airplane arrived at the balloon 45 minutes after passing the first plane.
Is this what they call mental mastrubation? If it is, is it supposed to hurt?
The total time is 90 minutes, or 1.5 hours.
In the airmass, the first airplane flies out from a point (the balloon) for 45 minutes. This means some distance is covered. A second plane passes it going the same speed and travels the same distance back to the starting point in the airmass. So the second airplane takes 45 minutes to fly back to the starting point.
None of the three, the balloon, or the two airplanes are affected by the movement of the airmass over the ground. Each one of them relative to the other are in perfect symmetry. The balloon is stationary (in the airmass) and the two airplanes are on reciprocal headings at identical indicated speeds.
The ground track and ground speed are a totally different matter. That is controlled by movement of the airmass that all three are in. This is the measurement you get with points A and B on the ground as the stationary point moves over it.
With the distance being 75 nm and the total time being 1.5 hours you can now calculate the speed of the airmass or the windspeed at altitude.
