Reserve at DAL
nwaredtail
Total Time
9000+
Can someone give me the gouge on reserve at DAL for domestic.
ie, do they have long call, how long is it, is everyone eligible, how long is short call?
At nwa, long call is bid daily, 12 hour call out (first to get the trip by the way) and there is a ratio on how many get it vs how many are available.
regionalcap
Total Time
8000
You can be assigned up to 6 short calls now. The long call is a 12 hour callout. Short call is 2 hour callout (for a 12 hour period). I have yet to figure out how they assign short call. You never know. It does seem that they typically give it to people with the highest available reserve days.
Meiguy
Total Time
4000+
I think there is a couple of threads floating around on this but here is some info for ya.
Everyone starts out on long call (12 hour call out). It's the default. They can reduce you to short call 8 times in a bid period. Although I think it's 6 with the new contract. Although every time I get short call I get assigned a trip before I actually start my short call period. As a 88 ATL FO I pretty much work everyday I'm on call. Last month I flew 92 hours and had 1 day I didn't get called out. Ex. Just finished a four day today. Got assigned short call for tomorrow. Already got a 2 day for tomorrow. This was for 6 on call days. How much you work definitely varies from base and equipment. As 88 NYC B I would maybe fly 30 hours or so a month. Other catagories can be similiar to this but 88 ATL B's are short. Each day you work on reserve gives you a raw score. The more you work the higher the score its. The higher the score the further down you are in your respective bucket (number of days available) to fly. This helps things be more predictable when assigning trips. You can guess on a high percentage whether or not your going to fly. There's a few other odds and ends but that is the jist of it.
Bert Harbenson
Active member
Total Time
5000
Sounds pretty similar. Everyone is given a long call line each month (12 hr.) and can be converted to short call (with 12 hr notice) up to six times per month. No specified callout time for short call, just "reasonable." However it is generally assumed to be two hours unless you are in NYC during rush hour or the like.
For long call each pilot is given a RAW (reserve avialibility weighting) score based on how much credit they have already flown in the month. The formula is in the contract--bring your TI-82 graphing calculator to figure it out yourself. Domestically the pilots are grouped into four pots--4 or more days on call, 3 days on call, 2 days on call, 1 day on call. The open time trips are then assigned in each pot based on who has the lowest RAW score.
As I said long call is 12 hours, but usually the trips for the next day are assigned at about 8 am the day before. Short calls are then handed out by around noon. This holds true most of the time unless there is some kind of irregular operations.
Overall a pretty good system that could be made better with a few minor tweaks. My biggest complant is the assignment of short calls. The contract gives no guidance on who gets them besides "scheduler discretion." That can make it kind of hard to plan as a commuter.
FlyingSig
Double Breasted _ _ _
Total Time
7000+
Reserve as an F/O at DAL = Work every day you are on call until you fill up for the month (does not apply during summer months)
*summer months at DAL = every month except SEP OCT & NOV
Total Time
7,500+
I've had pretty good luck bidding and getting what I want for short call days.
Delta is working on a PBS system for reserve. That will change the current system.
nwaredtail
Total Time
9000+
FYI, when NWA went to computer bidding for reserves, the satisfaction with everyone's schedules went down huge. We tried to cancel it, but of course, NWA said no.
qxdash8
Total Time
6000+
I might add: Short call on the ER is for a 24 hour period. Though this can be (and often is) adjusted by the schedulers. For example - short call assigned from 1300 to 1300 the next day. Then later that day scheduling calls to release you from short call at midnight so that they can put you back on short call the next day at 1300.
MXAV8R
Total Time
>1
Short call, pretty sure, NOT TWO HOURS. It is "readily available". If I am on short call in LAX and get called at 0600...well I be there asap. Scheduling understands that I dont control LA traffic. And in "normal" driving time I live about 1:40 away. At 0600, try about three hours...
Truckdriver
Total Time
5000
Well its coming in a couple of months so we'll see how it works. I have a feeling it won't be as nice as the line bid system we now have. I had PBS bidding for reserve in my previous life and it wasn't a good thing for pilots. If they can force the company to require that the PBS system awards a certain number of holidays and weekends to reserves, then it might be OK.
Truckdriver
Total Time
5000
The nice part about the Delta system is that if you "fill up" for the month which means you fly enough to get your credit time to the average line value, your done for the remainder of the month if you want to be. You hear of guys flying 90-100 hours on reserve, but they choose to do so. For the month of November in Atlanta, once you hit 75 hours you will be done. The ALV in the summer months is usually around 82ish.
PeanuckleCRJ
Hurrrrrrrr
Total Time
mucho
Reserve at DAL is pretty laid back these days. We are decently staffed. I've been flying 1 or 2 trips a month since summer time.
My record for short calls in a month is 5... it's been quite a few months since Ive actually been called on short call.
Not a bad life if you live in town. It's actually been a bit boring working so little. (I only flew 22 hours last month)
ASA_DFW
Total Time
7500
If you an MD-88 co-pilot and on reserve you will fill up for the month (75 hours). You will work almost every day. All the other categories are pretty well staffed.
PeanuckleCRJ
Hurrrrrrrr
Total Time
mucho
Good point. On the mad doggy dog you'll work your butt off on rsv.
Total Time
7,500+
Yes, but on the 88 you can make more than just about any other FO. Anyone want to explain "Rolling Thunder?"
Scope out RJ's
Banned
Total Time
20,000
Why? Its theoretically gone now that GS pay has been restored.
ACL65PILOT
Total Time
9000+
Hey they will use you for all your short call periods too. I have had eight two months in a row.
PeanuckleCRJ
Hurrrrrrrr
Total Time
mucho
You gotta start bribing those schedulers more!
Money plus talking to them in your "sexy voice" works wonders. ;)
Total Time
7,500+
You mean that voice you use when a call interrupts your EMHO, why it's Skippy at 04:35 on his fifth cup of coffee, just letting you know:
Mornin'Igota06:35tripforyouonyour06hundredshortcallperiod-gasp-fivelegs-a-daywithovernightsin-oh-idon'tknowthatcode-gasp-
thanks don'tworryabout dutyinweknowthisisashortcallThanks!
(click)
In your "sexy" voice, Wh what? Huh? Was that a dream? Where did Liz Hurley go?
