Metro752
5
- Apr 15, 2004
If you work at republic, read your contract. MKE falls under the "hybrid base" provisions of the contract. Among the information you'd find had you actually read it, is the fact that pilots cannot be displaced into a hybrid base. If nobody bids for it, the company has to come to the table no matter how many seats they put in the thing.
ARTICLE 17
BASES
(TOC)
Page 17.1
A. “Large” Bases
B. “Small” Bases
C. One Year Grace Period
D. Overnight Trip Requirement
E. Hybrid BasesPage 17.2
E. Hybrid Bases
-Page 17.1A. “Large” Bases
B. “Small” Bases
E. Hybrid Bases
1. Definition
2. Conditions
2. Conditions
a. Expansion/Growth
b. 2 Aircraft Minimum
c. Eighteen Month Limit
E. Hybrid Bases
3. No Minimum Cities Served
4. Voluntary Assignment
5. Current Bases Ineligible
6. Large/Small Bases Ineligible
ARTICLE 17
BASES
A. A “Large” base is defined as any base with at least twenty (20) hard lines
(not including build up or reserve lines) available for bid at that location
and where the Company flies routes that connect the base location with at
least two (2) other airport locations (an airport that is flag stopped does not
count toward the two (2) airports). No large base shall be opened unless
the previous conditions are met or the Union and the Company have come
to a mutual agreement.
B. A “Small” base is defined as any base that has fewer than twenty (20)
hard lines but no fewer that eleven (11) hard lines. The Company may
have a maximum of one (1) “small” base for every two (2) “large” bases.
The criteria for a “small” base shall be the same as for a “large” base,
except that the minimum number of hard lines shall be no fewer than
eleven (11).
C. The Company and the Union recognize that the above-stated criteria may
fluctuate periodically, but in the interest of stability, the Company would
not normally be required to close a non-conforming base unless one or
both of the above-stated criteria has not been met for at least a one (1)
year period.
D. Bases must contain lines that contain overnight trips away from base.
E. Hybrid Bases
-Page 17.2(not including build up or reserve lines) available for bid at that location
eleven (11).
year period.
E. Hybrid Bases
1. A Hybrid Base is any new base that opens after the date of signing
of the Agreement that does not comply with the criteria specified in
A. or B. above.
2. In order for the Company to open and maintain a hybrid base, the
following conditions must apply:
A. or B. above.
a. The aircraft assigned to the new base must be a result of
expansion/growth and not simply relocation of company
flying.
b. The base will have a minimum of two (2) aircraft to cover the
flying assigned to the new base. The Company shall be
allowed three (3) months to place both aircraft into service.
c. If a hybrid base does not comply with the criteria set forth in
paragraphs A. or B. within eighteen (18) months from the
date of opening, it will be closed unless it is otherwise
mutually agreed by the parties to keep the base open.
flying.
3. There is no minimum number of cities these bases must serve.
4. All vacancies will be filled with volunteers only. No pilot will be
displaced or forced to fill these vacancies.
5. The Company cannot restructure or close any current base and
then reopen it to take advantage of the provisions of this section.
6. The Company cannot restructure or close any base meeting the
criteria set forth in paragraphs A. or B. and then reopen it as a
hybrid base to take advantage of the provisions of this section.
