In the DFDR Analysis section of the report at 4800.5 seconds, it says the left column had 125 pounds of force applied nose up on the left column and 200 pounds nose down on the right.
OK.. and 2.5 seconds later the CAs pull was harder and no pull from the right column.... if it was a terrorist act don't you think the CA would have reported the FO pushing the other way? the fo never disconnected the AP. if it was a terrorist act don't you think he would have done it? again all you have to do is disconnect the ap and point the nose straight down, nobody is going to recover from that ie Egypt Air.
....because they want a cheap giggle from watching the high and mighty "big boys from the majors" get all in a tizzy because you can't get over yourselves long enough to see the tongue nearly poking through the cheek....I'm just sayin'"Regional F/O?"... I don't think Air India Express is a regional, they go as far as Dubai.... plus the a/c was a 737-800.
Not quite sure why you folks on this board keep confusing majors/regionals/legacies/cargo/etc anytime their is an incident...
It does seem odd. CA was gone for mere seconds before the plane pitched down. Luckily the lav was occupied at the moment and CA wasn't on the shiiiiter.
