1. Radio altimeter <10' altitude or air/ground safety sensor in the ground mode.
2. I'm assuming you mean ground operation...
auto speedbrake:
-lever armed
-speedbrake armed light illuminated
-both thrust levers retarded to idle
-main landing gear spin up <60kts
-right main strut compressed opening the mechanical linkage to the ground
spoiler shutoff valve
-radio altitude <10'
actually, not true. The speedbrake will deploy automaticly when you deploy the thrust reverse.
what?!?!
What?!?! , What?!?!
If you forget to arm the speed brake, Boeing designed it to auto deploy. It is the same system that deploys them on a rejected takeoff without the lever in the ARM position.
I don't recall ever reading that. What's the point of arming them then if they'll auto-deploy anyway?
