PreContact
- Oct 16, 2005
When taxiing, and given a taxi clearance by Ground Control of "hold short of runway XX, taxi to runway ZZ," we're supposed to stay with Ground Control up until the time when approaching the takeoff runway, then auto switch to tower, even if runway XX is an active runway in use?
Coming from the military, they were much more directive on frequency changes. I found this in the AIM:
4-3-14. Communications
a. Pilots of departing aircraft should communicate with the control tower on the appropriate ground control/clearance delivery frequency prior to starting engines to receive engine start time, taxi and/or clearance information. Unless otherwise advised by the tower, remain on that frequency during taxiing and runup, then change to local control frequency when ready to request takeoff clearance.
NOTE-
Pilots are encouraged to monitor the local tower frequency as soon as practical consistent with other ATC requirements.
I guess reading the note would tend to have you switch to Tower while holding short of an active runway, but this is incorrect procedure and contradictory to the preceeding paragraph. Am I reading this correctly? Thanks.
NOTE-
