Ralgha said:Likewise just because it's hard doesn't mean it's good.
Hell, in college, the worse the teacher, the harder the class, cause they didn't teach you anything and you had to learn it on your own.
The_Russian said:a 1900 CPT going to the CRJ would be a systems lesson rather than systems and re-learning how to fly an airplane again. Turbo props are a lot harder to fly than jets, especially without an autopilot to aid in those engine failures.
exchexflyer said:Someone who says flying a jet is harder than flying a 1900 obviously has never flown the 1900! Don't say things like this if you aren't even going to humor us to why you are right.
CapnVegetto said:Mesa's training dept. ...
The DHC8 dept. is another matter. At least a 50% fail rate in it. And it's all due to a bunch of 'club' instructors. If they like you, you pass, if they don't you fail. I was never a student in that dept. but they shared a building with us, and some VERY GOOD people I know never made it through the ground school. .
kevdog said:please, no offense, but can 1900 training be hard? sounds like previous 121 guys weren't pysched to be at GIA.
Ty Webb said:Any of you 1900 fondlers that think that your initial qualification in a 121 jet is going to be easier than the 1900 are in for one hell of a surprise. . . . . That's all I'm gonna say about that.
If you cannot operate an autopilot then you shouldn't be flying. Then again if you cannot operate an autopilot then you can't type or read or have any basic motor functions at all. How hard is it to press a button or two? Get over it. Flying a jet isn't that difficult....well depends on what you are doing with a jet. If you cannot fly the 1900 or an RJ then do something else. I don't want my family on your flight.CapnVegetto said:Just FYI, Mesa has about a 50% fail rate for 1900 captains upgrading to CRJ captain, and from what I understand, it's because "they can't work the autopilot."
white E said:If you cannot operate an autopilot then you shouldn't be flying. Then again if you cannot operate an autopilot then you can't type or read or have any basic motor functions at all. How hard is it to press a button or two?
kevdog said:To me, the speed difference in a 1900 has to give you a huge advantage from a jet. Doing the carnarsie climb out of JFK with an engine fire must seem like a walk in the park in the 1900 compared to a fast jet with a flight guidance system.
Dodge said:The speed limit change below 10?![]()
fxbat said:Ok I’ll bite
SABB auoto-coursen no prob. ATR auto-feather res. trq boost with type-4 no problem EMJ in to ORD on the speeds, make the turns, check the laso distance, get braking report, rvr and checklist at the speed of light (crap forgot the in-range and um’s with out an escort) $hit I think that heavy is going to clear in time.
If your worried about the Autopilot dude you’re screwed. Yes I miss the turbo prop and flying them in FL.
Is Gulf Stream hiring poor fo’s?
P.S. stomp on that rudder in a sweep wing jet like you would in a prop (it is the biggest control surface at v-2 and v-ref)You will do the nicest hard over (something similar to Greg leagues reverse pike, that split his head open 4 inches.)
