PT6 question
  • Thread starter Thread starter Nolife
  • Watchers Watchers 14
You can start a PT6 with the prop levers full forward or in feather. I personally would keep an eye on temps because of airflow over the engine and exhaust are reduced. Watch for possible heat buildup around cabin
Thx for the responses.
It seems that starting with props forward then feathering after start while waiting for avionics and clearance might be the way to go provided to wait time isn’t too long.
I’m looking for a way to reduce noise and stress on the parking brake while getting ready to taxi.
King Air ?
Yes King Air.
Some ideas, which I practice, to save the 3 hour (joke but...) time on ramp to run the Beech lawyer-designed checklists (it calls for FLAPS-UP like four times.....)
This is a modified order to the Flightsafety checklist but all items are covered.
1. Get clearance and ATIS via Ground Comm. Tell clearance delivery you will be "ready for taxi in 15 minutes". Set your altimeters now.
2. Get V-speeds before pax show up. You have temp off the OAT gage or off ATIS. You should have rough idea on weight of everybody and fuel, cargo.
3. Engine Start: Start the engines, flip avionics and EFIS on, and while that is coming up, do the engine checks, governor checks, etc. Auto-Feather checks also. Knock out the pressurization checks. Some airports you can't do engine runups on the ramp, so you need to exercise your discretion on this.
4. Avionics and EFIS should be online now, knock out quick AP and Yaw damp checks. Get your VOR's, FMS done. Copilot can also do this on the taxi-out, just don't be #1 for takeoff and have your FMS bungled. I personally don't fly out on the SID/etc via FMS NAV, I use old-school VOR radials until the climb-out, and if everything looks cool, I bring the FMS NAV up. I know Generation-Y doesn't do it that way but it is how I do it. I don't fly with an Ipod either....
Anyway, some ideas for you
Good advice. I have an approved realistic checklist but the problem is the ramp is too congested and small to do run-up items and the FMS and EFIS takes at least 5 minutes to start; goofy Chelton system.
Beech's checklist reads more like an instruction manual, takes way too long to accomplish, and it has too many redundant items. Their "Before Landing Check" takes so long that after you put the wheels down and finish reading it you're pulling up to the gate.
Yeah it is not fluid or pilot friendly.
Why do you not use the FMS for the SID? Not that there's anything wrong with that, I was just curious (always trying to learn something new).
When you start a PT6 in feather you put a lot of strain on the starter generator and can run the risk of burning it up, or draining that battery if starting without a GPU.
No, you really don't.
The starter has no idea whether the propeller is feathered or not. The starter is turning the gas generator, NOT the propeller. It's a free turbine engine. Exhausted gasses from the gas generator cause the propeller to turn. The propeller in feather, or out of feather makes no difference to the starter, and a feathered propeller puts no strain on the starter.
One can hold onto the propeller or tie it down,and it won't make any difference to the starter.
This is true on any PT6 installation, and equally true on the Piaggio Avanti as it is on the King Air series.
If the engine is started in ground idle, at approximately 47% Ng the GCU will disengage the starter. If you start in feather the chances of actually reaching that 47% are pretty remote, if not impossible.
Also untrue, as propeller RPM doesn't control Ng RPM during the start process. Again, one can bring the engine online without any movement from the propeller at all (in theory), assuming one can find a means of securing the propeller from movement against the resulting torque.
The gas generator does not require any particular degree of propeller movement or rotation in order to reach a cutout speed or complete the engine start.
Secondly, the oil tank is integral to the accessory gearbox. With no oil traveling to the prop hub you create an unnecessary amount of high pressure build up in the accessory gearbox. That in itself, is another reason why it's not a good idea to sit around in feather for long periods of time.
There is no pressure buildup in the accessory gearbox as a result of operating with the propeller in feather.
I fly out of some mountainous areas, at many non-home-base-airports, with a variety of King Airs, and have found that the chance to misprogram the box is greater than if I flew the same bird everyday, out of the same airport, everyday.
Flying a departure at night via FMS, in mountainous terrain, can bite you if the SID doesn't load correctly or they give you a new SID as you taxi to the Hold Short line (South America SOP).
At the end of the day, it works for me.
Makes sense to me, thanks.
A&PMECH, you're new at this right???
"The topic starter asked about how it would harm the compressor section and I don't see any reason why the compressor would be affected. I can see ITT spikes due to the free turbine rotating at a lesser speeds than the power turbine, which can cause poor exhaust scavenging. I have never seen that personally though. "
The free turbine, power turbine is one and the same. Other one is the compressor turbine which of course turns the gas generator.
Doesn't matter where the condition lever is for start or after start as others have pointed out here.
I've held the prop still while the engine was started a couple times, no big deal unless you move the prop, then get out of the way fast!
The theory is that one can hold onto the propeller, but even in feather, even at idle, there's significant torque acting on that prop. I've seen people tossed, trying to hang on, and I've seen eyebolts ripped out of cowlings on several occasions when propeller tethers weren't removed prior to the engine start.
Starting the 350 the prop levers are forward. As soon as the engine starts turning the oil pressure is building, no problems here. Maybe too much torque but I doubt it. In no time at all the prop is out of feather. On the 1900 there was a limit as to how long the prop could be in feather on the ground due to heating the windows. The Bandierante was the same. I heard a guy say he melted 350 windows because he was sitting still at idle too long. I dont see any problems with the compressor and props in feather. I have held the prop while engine was turning and no ignition for compressor wash. Not a comfortable feeling, just dont let go.
Ground ops in feather are bad for: prop blade erosion, engine cooling, FOD ingestion. They are allowed for GPU starting. I just got off the phone with Mr Beech.
